After viewing Loud's LED thread, I had the urge to update most of the the bulbs behind my gauges to LEDs. No more dull lookin' gauges at night.
Bulbs replaced were the speedometer, tach, fuel, water, oil, and battery. Gear shift indicators, turn signals, and brights were updated as well. Didn't feel the need to change other bulbs such as VSC/TRAC, ABS, Brake, etc.
To remove the instrument panel, gently pull the black cluster panel finish towards you. It is fastened via clips and shouldn't break. The black panel houses the dimmer switch which can either be disconnected or just swung out of the way.
Unscrew the 2 black screws at the top and bottom corners of the instrument panel. Next, loosen the 2 bigger gold captive screws at the bottom of the inst. panel. Once loose, gently pull the panel towards you. If it doesn't move freely towards you, you need to further loosen the screws as they are connected to wire harness connectors behind the inst. panel.
Remove the glass inst. panel cover and top of the steering column cover. (thx Loud) You should now be able to slide the inst. panel to the left of the steering wheel.
Bulb locations updated
The 3 types of bulbs that were replaced
Shift indicator lights were replaced with this Type B
from autolumination.com: $3.49 ea.
I plan to change these as they are TOO BRIGHT at night.
All other bulbs. V-LEDS.com #74 6k white: $6.99/pair
Keyring light also takes the same #74 bulb which I switched out too.
Thank you for the detailed description of how to pull the cluster! I always have a low-grade phobia about pulling these for some reason...
