- Thread starter
- #721
Waiting for the @cruiseroutfit xmas sale to complete my part-time conversion! My last 2 purchases were after the black Friday sale and I need to grab the high range 10% underdrive and the 3.1:1 low range set-up.
Coming soon
I was on the fence almost did this kit but didn’t want to hassle with my rw wheelsI installed the part time kit last year and have Rock Warriors. I found out they do not fit over the new locking hubs so I had them all (5) machined to fit. Kind of a bummer as the center TRD caps don't fit now but oh well. Another $250 to have that done but I love the part time so it was worth it !
Coming soon![]()
Well f%^& me! Went to order the transfer case parts and the high range gear conversion kit is out of stock.
Had a few left as of this morning.
Nooooo! What part do you need? Doing underdrive in your t-case? This is the new part:
Sumo Gear Land Cruiser Transfer Case 10% Underdrive Gear Set - Fits 01/1998-07/2007 100/LX470 Series Applications (TCG100470UDHR)
Sumo Gear Land Cruiser Transfer Case 10% Underdrive Gear Set - Fits 01/1998-07/2007 100/LX470 Series (TCG100470UDHR)cruiserteq.com
It's a bit less than the previous underdrive combo of parts and in stock![]()
@cruiseroutfit so the updated underdrive kit comes with a modified idler gear, how does this work with the low range 3:1 kit idler gear?
Perfectly! The previous kit also required the modified idler but it was a separate kit. This is a brand new application (we are the first of install/offer) and we've re-bundled them to save some $$$ from the previous offerings. They are 100% compatible with the 3.1:1 low range kits we offer.
Ordered, thank you sir!
Looking forward to getting this and the part-time kit in.
Still waiting on the T-case gear parts I ordered so I'm waiting to install the PT kit until I have everything so I only need to open the box once.
But in the mean time, are those that installed the kit removing the A/T P light bulb from the cluster since the T-case will stay in neutral?
Or, reverse the polarity of the switch so the A/T P lights on when in H or L?
I have my cluster out replacing some bulbs and figured while it's out...
The T-case is not run in neutral. You run in high or low.
I may be reading this post wrong, but with the PT kit replaces the rear side gear, pinion gears, shaft, and pin in the "center diff" with a spool and spacer. The spool permanently connects the output shaft assembly to the rear output.Center diff stays locked when in 2wd, t-case functions as normal. T-case in neutral and you're not moving at all.
I typed all that for nothing!!!Typo in my post, meant when in 4wd.
