Write up on the headers.
Tools/Parts needed:
Left hand drive headers and cats ($1020 usd) or
Right hand drive headers and cats ($980 usd)
Shipping to the east coast was about $300. I also had to pay fedex $240 for import fees/ dutys
Oxygen sensor extensions. The description says that you don't need them, you do
-E10 female torx socket, must have (
here's the set that I used)
-Medium height 14mm socket
-Deep socket 14mm socket
-14mm stubby wrench, you will not get the job done without one.
I got this set
-An extension set for 3/8th drive. I used a 2 foot extension and combinations of
these
-Swivel joints, included in the set linked above
-You may need extractors if you are in the rust belt. I bought
this kit, but didn't end up needing them
-Impact driver
-2 foot breaker bar and 3 foot breaker bar
90126-10015 stud x16
90179-10070 nut x16
-17mm wrench and a socket
Process:
Keep in mind during this that I have a RHD UZJ. Mine does not have EGR.
First things first, jack up the car and remove both wheels as well as splash gaurds. The job is impossible without this.
You will need to then remove the midpipe bolts and the cats. I opted to use an impact to break them off and it was fairly quick. It took longer to disconnect the o2 sensors than to remove the bolts. The Rhino kit comes with new bolts and gaskets.
Next, get rid of the heat shields. There is four 12mm bolts on each one, they aren't too bad to get to from the wheel well. Getting the heat shields out is a lot worse, though. I found it easiest to wedge them up to the front of the vehicle, and push them down. You will have to sort of wedge them between the fan blades and be careful of the radiator
Drivers side:
The drivers side was easy, except I made some mistakes. Remove all 8 nuts from the OEM headers, they aren't too horrible to get to. The top ones you will use a 14mm deep socket and a breaker bar dropped down from the top of the motor. The bottom ones you have to get a bit creative. You for the rear two I used a swivel joint and the impact gun from the wheel well. The front two were a bit different, you have to use long extensions from the bottom of the car with a swivel joint
If you don't live in the rust belt, you aren't going to have issues getting the nuts off. If you do, use your extractors. On both sides the OEM headers will slide right out from the rear where the cats were with no issues.
For installing the rhino headers, you will need a bit of prep. Go ahead and
drill/file the outer most holes on the outer most sides of both headers. This will save you a
significant amount of time
-Use your reverse torx bit to go ahead and remove all the studs
-Clean the mating surface of the motor with brake clean and 000 steel wool
-Install all studs except the rear most top two studs
-Mount your headers on the studs, you should have plenty of clearance
-Install your rear most top two studs with the header on the motor
-START all 8 nuts,
then hand tighten the bottom nut second from the front first. If you dont do this, you will find yourself in the situation I did below where a wrench will not clear it
-From here you are going to use a normal wrench and extension from the wheel well on the top 3 rear most nuts, a stubby wrench on the front most top nut
The bottom nuts will almost entirely be stubby wrenches except one, you have to access it from a gap below your cv axle with a long extension and a swivel:
Passenger side:
Removal of the OEM one is basically the same as the driver side and took me about 15 minutes.
Go ahead and save your self alot of effort and trial and error. Remove all studs, clean the surface, then just go straight to removing the 3 nuts on the motor mount. Lift the motor from the bell housing between the motor and the trans about 3 inches, until your fan blade is about to touch the shroud. Be aware of your heater tees, mine broke during this.
sa
This will give you the clearance to get your headers in. Just like the drivers side, put all studs in except the two top rear most studs. Mount your headers and use your female torx bit to mount the two remaining studs.
Mount your headers and go ahead and start all the nuts, this part is a lot worse than the other side. You will have to use a stubby wrench for just about every nut (except the top two rear most- those are from the wheel well. Most of the bottom ones will be accessed by laying on your back and blindly starting them by hand.
This side the headers are shaped different, and the first nut you will actually tighten halfway, that's the frontmost bottom two nuts. I did each a little bit at a time until I couldnt tighten them by hand.
From there I went ahead and tightened the remaining by hand until I couldn't any more.
After that you will basically use the stubby wrench for every single bolt. The bottom nuts that are second and third from the front you'll have to use the open end of the wrench. You can't see while you're doing this and if it's anything like my experience you'll spend 30+ minutes on each nut. The top rear two nuts, and the second rearmost nut on the bottom are easily accessed from the wheel well and you'll have no issues with them.
Once you've successfully tightened each nut as much as you can with little to no leverage, you're going to have the pleasure of getting your motor mount back on. Get the three nuts started so that everything is lined up, you'll have to lower your motor a small amount first.
From there lower your motor a small amount, hand tighten them, and repeat that a few times until the motor is off of the jack. You have to pry a wrench between the headers and the mount and tighten it with the open end a very small amount at a time, it's a frustrating process and takes a while because you'll likely be laying under the car doing it blindly
From here it's easy. Just install your sensors and route them away from heat to the best of your ability. Install your cats with the nut side facing the motor.
This job doesn't require any technical skill but it does require some specific tools and a lot of patience. I wish I could have taken more pictures but the space that you're working with is super tight
