Knuckle rebuild question
NorCal
I’m in the process of rebuilding both knuckles. How important is it that the rubber gasket between the felt wiper and metal ring gets put on with the ridge facing the diff?
If you already installed it I think it should be pretty easy to turn itself over without taking off the knuckles. I think the ring is actually keeping the rubber in and the felt is keeping the chunks and the bearings out. Having the lip facing inside might wear out the gasket prematurely.
Yeah...I threw DS on with ridge facing away from diff. Not sure how I would turn that without removing the knuckle again.
Pretty sure you can just roll it over on itself, if that make sense, once you get the metal plate and felt out of the way. I would have to look at it up close for sure though.
If you're talking about the rubber seal on the side of the knuckle towards the differential, under the steel ring and the felt gasket, you can take it apart and turn it without removing anything other than the bolts on the steel ring. The grease should be thick enough it won't "run" out.....
Should be able to cure it in about 15 minutes......
The only way is to pull the knuckle, I have done several and the rubber is one piece. I think it's not the end of the world, run it and just watch it
[/Q
it goes over the steel ring :meh:
Run it and check, otherwise you do need to pull it apart .
Yeah, I just tried it with a spare seal I have. You can definitely turn it inside out, but it doesn't like it. Turning it inside out, is much different than turning it around....oh, well.
OK, it's been a long time since I did my front axle and I may have been thinking of the old Chevrolet I had many years ago that had a split seal that looks just like it.
In the case of the Chevy, the rubber seal had a single slit and you placed the slit at the top, so that seal could be replaced without removing the knuckle.
You could do that as an alternative, then use some "The Right Stuff" to caulk the slit back together....but that's not how Mr. T designed it either......
If you need to just take the trunion plate off the top and the steering arm off the bottom of the knuckle. You can then take the whole knuckle assembly off. Obviously you'll need to take some more stuff off like the wheel speed sensor, brake caliper, and snap ring,etc. if you have already put them back on. Don't know how far you've put it back together but its probably best to do it now rather than later since you'll still have to take the whole knuckle assembly off when the seal fails.
Assembled it with the exception of the caliper and tie rod.
take off the drive flange and the snap ring. Then take off the wheel speed sensor, top trunion bearing pin plate, lower steering arm. Take off the rear wiper plates. That should be everything you need to take off and you can just pull the whole knuckle assembly while keeping at least the wheel bearing preload. It's the trail repair way to get to those parts
If you hired a shop to do the work would you be upset if they did it backwards? Sounds like a hassle but I'd get this one correct so you don't have to get back in there later to remedy.
If you need to just take the trunion plate off the top and the steering arm off the bottom of the knuckle. ...
Don't need to remove the steering arm, just the top plate and the knuckle will come off. Unless there is a hardware problem, we never remove the steering arm when doing knuckle reseal jobs.
Nope I never do either.
That maybe possible, but you still need to wrestle the Birf, hub wheel bearings the weight of that, and dropping the lower trunion bear and trying to get all that in place, and get everything in place no way, the flipping is probably better or just let it ride and I am pretty sure it will survive
