ATwoZ
Been trying to come up with a storage/mounting location inside the truck for my "Tire Table" and it finally hit me a couple days ago that I could mount it underneath the shelf. I tried bungees and straps and nothing held secure. Then I found these "Threaded Star Knobs" and decided to see if the bolts would fit in the little holes... and they fit PERFECTLY! Everything is nice and secure tightened up flat against the shelf and out of the way. In fact it extends further rearward than the shelf does and could be used as additional shelf space for soft goods. I'm throwing my heavy jacket/hat/gloves on it for quick access.
Tire Table:
I have a similar setup with the tire table, a couple things that I did different...
1.. I rotated the table 90degrees in my mounting and that way it overhangs a lot less, I was able to mount it to the side without interfering with anything.
2.. I got some black rubber weatherstripping and mounted it under the KAON, you can't hardly tell unless you look, but it gives enough cushion to silence any rattling with the tire table (started noticing some with bumps around the neighborhood, and would have been unbearable offroad)
