Trade Jurassic Park 96 FZJ80 Exceptionally Maintained, Upgraded and Built - Locked 90+ Pics
or For sale 96 FZJ80 Exceptionally Maintained, Upgraded and Built - Locked 90+ Pics
SOLD $16,500 OBO
I have a 1996 FZJ80 I'm looking to Trade or Sell. I think current value is ~18K give or take, not sure exactly what I'm looking for, FJ40 V8 DD, maybe a GX or LX/100, I think a V8 something a little more DD'ish, 4Runner, Tundra, Newer Tacoma anything else that might spark my interest Ill take something plus cash or just cash.
If you have trade offers please email me info, price and pics. The more detail the better.
PM Text Call Email 760-550-2258 schulz__7@hotmail.com
This link is the quick and dirty, if this wets your whistle keep reading
https://forum.ih8mud.com/80-series-tech/581368-introduction-jurassic-park.html
No pets and none smoker, title in hand, currently has 147K miles. The odometer was replaced by the previous owner because the trip meter had stopped working at 142K miles and he replaced it with one that had 125K on it. I still have the old one. The odometer now reads 130K. I have DD'd her for the last 5000 miles with only one, 1/2 day of wheeling at the badlands in Attica, its far over built for my use in the flatlands of the midewest and too nice for me to beat on the tight wooded trails.
She is a factory locked rig that has been very well maintained and is stupid clean. No rust. Anything seen in the pictures is dirt. Below is a list of maintenance etc. I have the Excel sheet with all maintenance and mileage as well as receipts for everything from the previous owner that I have also been adding to. I can't think of anything off the top of my head that doesn't work, except the radio antenna it makes the motor noise but doesn't move.
90+ Pics - Jurassic Park 96 FZJ80 pictures by 7schulz - Photobucket
Maintenance:
Engine:
Oil changes approximately every 5k miles.
Routine cooling system flushes. 142k New Toyota Brass tank 3 core copper radiator PN: 16400-66040
New battery at 135k
https://forum.ih8mud.com/80-series-tech/206807-upgrading-stock-alternator-130-150-amp.html to Toyota sequoia 150 amp alt. Alternator from vehicle with 29k miles. Wiring,150 amp Fuse block: 782-1143, 150 amp fuse: 782-1138 from Napa 136k
New OEM belts, plugs, wires, distributor cap, rotor, pcv valve and grommet, new vent hoses at 136k
Rebuilt a Toyota reman starter 28100-66060-84. Parts from CDAN 28226-66060 starter kit, 28226-72010 starter kit, 28235-54380 plunger at 137k
https://forum.ih8mud.com/80-series-tech/102633-blue-fan-clutch-mod.html Blue Hub Fan Clutch at 138k
index PHH and FHH at 138k
https://forum.ih8mud.com/80-series-tech/449629-installed-oil-seperator-my-80-a.html Oil separator at 140k
https://forum.ih8mud.com/80-series-tech/412261-charcoal-canister-great-option.html Charcoal canister at 140k
replaced Fuel Filter with OEM P/N FILTER SET FUEL 23300-69045 (4 new gasket washers) and replaced fuel tank sock filter. Part #: 23217-16490 SO13 FILTER, 23219-03010 SO13 CLIP FUEL, 77169-60010 SO29 GASKET FUEL, 90430-12026 SO41 GASKET at 140k
Custom 2.5" Exhaust high flow cat 608386, flowmaster 42441, backwards glasspack for resonation.140k
Transmission:
fluid exchange with Mobil 1 ATF at 136k Machine used BG pf5 (model 12q) Drained and cleaned trany pan and installed new filter.
Transfer case:
"service" at 136k filled with Valvoline 80w90 syn.
PIN7+CDL mod
Axles:
IPOR removed 3rd member and regeared to 4.88, rebuilt front and rear axle including knuckles 128k
New Toyota Spider Kits in the rear drive shaft at 136k
Installed BudBuilt Inc. Tie Rod, Relay Rod, with Japanese 555 rod ends from Cruiser Outfitters. P/N TRE69095 138k
Cruiser Outfitters
rebuilt front drive shaft at 138k
Replaced Front sway bar link bushings (axle end) Bushing Toyota P/N 90385-11021 BUSH, Duralast #532059 FA7436 Swaybar Bushing 140k
Routine drain and refills on both axles.
Power Steering flush and tundra trans cooler for PS cooler at 136k using Mobil DTE 24 light, ISO 32 modeled after this but mounted like a trans cooler:https://forum.ih8mud.com/80-series-tech/343463-power-steering-cooler-install.html
https://forum.ih8mud.com/80-series-tech/135349-parking-brake.html Ebrake rebuilt at 139k
Toyota brake calipers and pads at 140k plus a full fluid flush
5 Tire rotation approx every 3k
A/C recharged at 140k
Receipts for pretty much everything listed and a lot more not listed.
Some of the mods in order they were installed
FOUR WHEEL DRIVE side molding from Dan for door ding protection
Husky front, rear and cargo mats
IPOR Skid[/URL] FJ80 Skid Plate [IPOR-SKID80] - $345.00 : Iron Pig Off Road, Toyota Land Cruiser experts
Slee complete 4"bolt in lift[/URL] basically a complete 6" kit with 4"springs Slee - Toyota 80 Series Toyota Land Cruiser Suspension Slee - Toyota 80 Series Land Cruiser 4" and 6" Lift Details
Tundra wheels with cooper STT 35/12.50r17
ss81-HF Safari Snorkel System Safari Snorkel
LINE-X Sprayon Bedliners, Protective Coatings, Truck Bed Coating, Floor Coating, Industrial Flooring Color matched LineX'd roof
Rear Storage Drawers
Disco cup holder
Installed Pioneer TS-G1643R in all four doors to replace the factory speakers[/URL]
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=148&modelId=MODL028629" installed JVC kw-xr810 headunit
http://www.secondskinaudio.com/vibration-mat/damplifier-pro.php Installed lx450 wood trim and Second Skin Audio Damplifier Pro to doors Sound Deadening Materials for Noise Reduction | Second Skin Audio
LX450 Wood Grain matched kit for interior
Rear cargo light installed
Toyota FJ60 hood prop The factory gas struts still work.
Modified ARB
Tabs from Excel
MISC
118415 purchased - **Note **Previous Owner I purchased at 142K miles
119318 serviced front and rear diff. serviced transfer case.
Removed and repainted gold vehicle emblems silver. Used 3M two sided tape to reattach.
$376.86 FOUR WHEEL DRIVE side moulding door guards
$251.31 Husky front rear and cargo liners
$345.00 Installed IPOR skid plate
123000 $3,465.00 Slee 4"lift 1" spacers up front
123100 $2,002.36 Installed 5 spoke tundra wheels and Cooper STT 35-12.50r17
$413.22 snorkel
$546.25 LineX the roof.
128013 $2,660.81 IPOR removed 3rd member and regeared to 4.88, rebuilt front and rear axle including knuckles
135400 $813.90 Installed Storage Drawers
$20.00 new rear wiper motor and linkage
135739 $85.00 Battery- New Napa Legend 75
$15.00 Front entry assist handles
136020 $256.74 Upgraded to Toyota sequoia 150 amp alt. Alternator from vehicle with 29k miles. Wiring,150 amp Fuse block: 782-1143, 150 amp fuse: 782-1138 from Napa. Photomans alternator bracket
136020 $54.00 Added Tundra trany cooler in place of the heat sink (paper clip) from ebay for the power steering system output lines of the steering box. Got new hoses from Napa. 3/8" trany lines.
136217 $53.95 Added Discovery Cup holder.
137750 $150.00 Installed Rebuilt Toyota reman starter 28100-66060-84. Parts from CDAN 28226-66060 starter kit, 28226-72010 starter kit, 28235-54380 plunger
$5.00 1FZ-FE engine decal
138000 $70.00 upgraded PHH and FHH
138145 $50.00 New Blue Hub Fan Clutch. Refilled with 5 &10k cst silicone oil
138345 $87.80 Installed Pioneer TS-G1643R in all four doors to replace the factory speakers
138345 $349.20 Installed BudBuilt Inc. Tie Rod, Relay Rod, with Japanese 555 rod ends from Cruiser Outfitters. P/N TRE69095
139600 $197.00 installed JVC kw-xr810 headunit
139623 $406.44 Installed lx450 wood trim and Second Skin Audio Damplifier Pro to doors.
$319.00 Wood Grain for interior
$20.00 Cargo Light installed in upper rear hatch using spare dome light from Bowser.
hood prop
140118 $35.00 Installed oil separator after the PCV valve and fuel filter to other vacuum line
140118 $52.00 Installed new charcoal canister Auto Zone VC120 Canister from Grand Am.
140150 cell cradle
140533 replaced Fuel Filter with OEM P/N FILTER SET FUEL 23300-69045 (4 new gasket washers)
140641 Charged A/C system
140698 replaced fuel tank sock filter. Part #: 23217-16490 SO13 FILTER, 23219-03010 SO13 CLIP FUEL, 77169-60010 SO29 GASKET FUEL, 90430-12026 SO41 GASKET
140858 $575.00 Custom 2.5" Exhaust high flow cat, flowmaster, backwards glasspack for resonation.
140860 $22.37 Replaced Front swaybar link bushings (axle end)
142870 Installed working (trip odometer) odometer with 125338 miles
127050 $120.00 Installed 1.5" aluminum wheel spacers
127050 $40.00 Installed rear mud flaps
127100 $712.93 Toyota Brass tank 3 core copper radiator PN: 16400-66040 + install at Zionsville Auto Service
Total ~ $14,500
OIL
Date Mileage Oil Type Amount Oil Filter Air Filter Notes
9/5/2007 122768 Mobile1 0W-40 8 quarts Napa 1515 Oil Filter
5/10/2008 125671 Shell Rotella 5w-40 8qts/2gal Napa 1515 Oil Filter Napa Gold Air filter 2159
3/21/2009 130660 Mobile1 0W-40 8qts/2gal Napa 1515 Oil Filter Napa Gold Air filter 2159
2/27/2010 136156 Mobile1 5W-40 Turbo Diesel 8qts/2gal Mobile 1 M1-102 Napa Gold Air filter 2159
3/19/2011 140150 Mobil Delvac Super 15w40 2 gal Toyota 20004 filter
4/13/2012 127000 Mobil Delvac Super 1300 15w40 2 gal Toyota Syn Filter
OTHER MAINTENANCE
Date Mileage Notes
3/22/2009 130660 1&3/4 gallons Napa Antifreeze 1&1/2 gallons distilled water.
12/18/2009 135739 Battery- New Napa Legend 75
2/19/2010 136020 Upgraded to Toyota sequoia 150 amp alt. Alternator from vehicle with 29k miles. Wiring,150 amp Fuse block: 782-1143, 150 amp fuse: 782-1138 from Napa
3/6/2010 136217 Replaced belts with new OEM.
3/6/2010 136217 plugs, wires, distributor cap, rotor, pcv valve and grommet, new vent hoses
3/30/2010 137750 Rebuilt a Toyota reman starter 28100-66060-84. Parts from CDAN 28226-66060 starter kit, 28226-72010 starter kit, 28235-54380 plunger
5/23/2010 138091 Drained and refilled the fan clutch (Factory Eaton Clutch) with 5000 cst oil.
5/24/2010 138132 Complete cooling system flush. Used a bottle of Napa radiator cleaner. Replaced thermostat/gasket, PHH and firewall heater hoses. Filled with 50/50 distilled water and Napa green antifreeze
6/5/2010 138145 New Blue Hub Fan Clutch. Refilled with 5 &10k cst silicone oil sprayed mud out of radiator's outside.
3/13/2011 140118 Installed oil separator after the PCV valve and fuel filter to other vacuum line
3/15/2011 140118 Installed new charcoal canister Auto Zone VC120 Canister from Grand Am.
4/13/2011 140448 ran a 1 pint bottle of seafoam through the vacuum lines. Lots of smoke.
5/7/2011 140533 replaced Fuel Filter with OEM P/N FILTER SET FUEL 23300-69045 (4 new gasket washers)
6/10/2011 140698 replaced fuel tank sock filter. Part #: 23217-16490 SO13 FILTER, 23219-03010 SO13 CLIP FUEL, 77169-60010 SO29 GASKET FUEL, 90430-12026 SO41 GASKET
7/28/2011 140858 Custom 2.5" Exhaust high flow cat 608386, flowmaster 42441, backwards glasspack for resonation.
10/8/2011 141000 bottle of seafoam treatment into gas tank
4/28/2012 127100 New Toyota Brass tank 3 copper core radiator PN: 16400-66040
AXLE HISTORY
Date Mileage Notes
2/19/2007 119318 80W-90 GEAR OIL W/LS SERVICE FRONT DIFFERENTIAL SERVICE REAR DIFFERENTIAL Cumberland Auto
9/15/2007 123000 Slee 4" Lift installed
1/12/2008 124466 drained axles and added new napa gear oil front and rear.
10/9/2008 128013 IPOR removed 3rd member and regeared to 4.88, rebuilt front and rear axle including knuckles
10/11/2008 128600 drained axles and added new gear oil front and rear. 80w-90
10/31/2009 135450 drained axles and added new gear oil front and rear. 80w-90
3/6/2010 136217 Replaced rear drive shaft ujoints. OEM Toyota Spider kits.
7/4/2010 138345 Installed BudBuilt Inc. Tie Rod, Relay Rod, with Japanese 555 rod ends from Cruiser Outfitters. P/N TRE69095
7/6/2010 138350 Alignment at Freeman Tire
8/27/2010 138590 Replaced front axle inner and outer wheel bearings, races and inner axle seal with Timken parts.
9/3/2010 138620 Rebuilt front drive shaft.
12/11/2010 139610 drained axles and added new gear oil front and rear. Coastal 80w-90
8/2/2011 140860 Replaced Front swaybar link bushings (axle end) Bushing Toyota P/N 90385-11021 BUSH, Duralast #532059 FA7436 Swaybar Bushing
Power Steering Flush
Date Mileage Oil Type Amount Notes
2/21/2010 136020 Mobil DTE 24 light, ISO 32 3.5 qts Spilled some fluid so amount is estimate. Added Tundra trany cooler in place of the heat sink (paper clip) from ebay for the power steering system output lines of the steering box. Got new hoses from Napa. 3/8" trany lines.
Brake System
Date Mileage Notes Amount Type
10/23/2010 139250 Rebuilt rear e-brake. See receipts folder for parts list.
6/17/2011 140698 Installed new Toyota Reman front and rear calipers. New OEM pads front and rear
6/17/2011 140698 Full brake system flush. valvoline Synthetic DOT 3-4 fluid
Note** looks like photobucket mixed up some of the old and newer pics, the third row seat is not available, there is the storage system in the back. Also the rear bumper has one corner that has been sprayed a different color to cover a few scratches that I haven't been able to locate locally the matching color for the front bumper and running boards.
Clicked over 130K today, also see the D light still works :D and a rock solid 600 rpm at idle. Wanted to also note I have been using 303 Aerospace protectant on dash and other plastics including the snorkel and Lexol on the seats.
Very nice rig! All she needs is a new owner to put the right tire on and get her dirty.
GLWS
I was tempted when EGR80 had it for sale. He listed it for a great price. Definitely an awesome 80!!!
GLWS!
Agreed, ERG80 did an amazing job on this rig, I read through his T100 build he is doing now and it's top quality work, I was lucky to snag this one, more truck than I need, I thought if I bought an awesome off road truck I would actually go off roading more. Not the case, I don't even like dust on my vehicles.
Worth every penny. She's an amazing rig and would cost a lot more to build one similarly.
Agreed, EGR80 did an amazing job on this rig, I read through his T100 build he is doing now and it's top quality work, I was lucky to snag this one, more truck than I need, I thought if I bought an awesome off road truck I would actually go off roading more. Not the case, I don't even like dust on my vehicles.
Thank you. The truck is handy and what I need at this time but I still miss that Cruiser.
