Introduction of "Jurassic Park"
Zionsville, IN
This is what she started life as and was purchased in 2007 by another mud member ERG80 so I can't take credit for any of the build but it is one awesome rig. This is the best maintained, clean, loved and modded cruiser I have seen come through the classifieds on Mud. I bought her to replace my original 1993 Dark Emerald Pearl that was hit. https://forum.ih8mud.com/80-series-tech/352090-newbie-intro-93-fzj80.html This one is everything my first cruiser dreamt of being.
1996 Land Cruiser Dark Emerald Pearl F&R Lockers.
Maintenance:
Engine:
Oil changes approximately every 5k miles.
Routine cooling system flushes. 142k New Toyota Brass tank 3 core copper radiator PN: 16400-66040
New battery at 135k
Upgraded to Toyota sequoia 150 amp alt. Alternator from vehicle with 29k miles. Wiring,150 amp Fuse block: 782-1143, 150 amp fuse: 782-1138 from Napa 136k
New OEM belts, plugs, wires, distributor cap, rotor, pcv valve and grommet, new vent hoses at 136k
Rebuilt a Toyota reman starter 28100-66060-84. Parts from CDAN 28226-66060 starter kit, 28226-72010 starter kit, 28235-54380 plunger at 137k
Modified Blue Hub Fan Clutch at 138k
Samco PHH and FHH at 138k
Oil separator at 140k
Charcoal canister at 140k
replaced Fuel Filter with OEM P/N FILTER SET FUEL 23300-69045 (4 new gasket washers) and replaced fuel tank sock filter. Part #: 23217-16490 SO13 FILTER, 23219-03010 SO13 CLIP FUEL, 77169-60010 SO29 GASKET FUEL, 90430-12026 SO41 GASKET at 140k
Custom 2.5" Exhaust high flow cat 608386, flowmaster 42441, backwards glasspack for resonation.140k
Transmission:
fluid exchange with Mobil 1 ATF at 136k Machine used BG pf5 (model 12q) Drained and cleaned trany pan and installed new filter.
Transfer case:
"service" at 136k filled with Valvoline 80w90 syn.
PIN7+CDL mod
Axles:
IPOR removed 3rd member and regeared to 4.88, rebuilt front and rear axle including knuckles 128k
New Toyota Spider Kits in the rear drive shaft at 136k
Installed BudBuilt Inc. Tie Rod, Relay Rod, with Japanese 555 rod ends from Cruiser Outfitters. P/N TRE69095 138k
rebuilt front drive shaft at 138k
Replaced Front sway bar link bushings (axle end) Bushing Toyota P/N 90385-11021 BUSH, Duralast #532059 FA7436 Swaybar Bushing 140k
Routine drain and refills on both axles.
Power Steering flush and tundra trans cooler for PS cooler at 136k using Mobil DTE 24 light, ISO 32 modeled after this but mounted like a trans cooler:https://forum.ih8mud.com/80-series-tech/343463-power-steering-cooler-install.html
Rear Ebrake rebuilt at 139k
Toyota brake calipers and pads at 140k plus a full fluid flush
5 Tire rotation approx every 3k
A/C recharged at 140k
Receipts for pretty much everything listed and a lot more not listed.
Some of the mods in order they were installed
FOUR WHEEL DRIVE side molding from Dan for door ding protection
Husky front, rear and cargo mats
IPOR Skid
Slee complete 4"bolt in lift basically a complete 6" kit with 4"springs
Tundra wheels with cooper STT 35/12.50r17
Safari Snorkel
Color matched LineX'd roof
Rear Storage Drawers
Disco cup holder
Installed Pioneer TS-G1643R in all four doors to replace the factory speakers
installed JVC kw-xr810 headunit
Installed lx450 wood trim and Second Skin Audio Damplifier Pro to doors
LX450 Wood Grain matched kit for interior
Rear cargo light installed
Toyota FJ60 hood prop The factory gas struts still work.
Modified ARB
Plus many extra accessories
bad ass rig man. nice find.
here is some more quotes from the movie !!!
"you listening to the voice of john Hammond Spared no expense!!!"
"what do they have king kong behind there"
" $5000 $10,000 and people will pay that............. we could have a coupon day or something hahahah"
Best Cruiser ever.
If you ever decide to repaint it I think this would be fitting:
Nice, you built it man, I'm just going to enjoy it. Thanks again for everything. You really are a man among men.
You think Line-X could pull that off?
Thank you.
Yeah. looks like an easy line-x job. haha. Video their response when you ask them.
Nice rig!
Sideways snorkel???
In addition, the detachable Safari air ram can be rotated to any position. This means great peace of mind for those who plan to travel in cold or high altitude conditions where heavy snow falls are anticipated. By rotating the air ram to face away from the prevailing wind/direction of motion, the air ram delivers additional protection from the choking effects of snow build-up inside the air intake.
Very clean Rig. Do you have a link your particular (or PO's in this case) catch can install off of the PCV?
Just a FWIW, I live at 8,000' in a place called "Snowmass", and a forward facing snorkel is not an issue. I doubt it would be in Indiana either...;)
