Jerry Can Location
Tommy Shumpert
Spring/Woodlands Texas
I want to move my Jerry Can from my spare tire over to were the license plate bracket connects to the lower door with the 3 screws. And then attach license plate bracket to the can.
Is the 3 screws enough to hold that can without bending door?
anyone done this?
thanks
I wouldn't. Full of gas the can and mounting bracket will be at about 40 pounds. Waaaaay more than a license plate. Also, if you don't like things rattling you won't like the effect the gas can will have on your rear doors. It would also likely cause premature wear on the door hinges.
Thanks. That's what I was thinking. Had seen some pics of a jerry can in this location on some original FJ's, but guess the mount is different.
Personally, I am not a fan of adding an additional pile if weight to the OEM tire carrier and hinges. Yeah, "back in the day" I did it, but eventually it causes metal fatigue and stress fractures where the OEM hinges attach to the tub. It's bad enough dealing with the dent in the quarter panel when you hit something with the tire.
There are lots of good options for ready-to-install carriers that mount to the rear cross member and can hold a LOT of weight. If you have good fab skills you can buy the parts and build your own. Ruff Stuff has a full line of tire carrier parts including heavy duty hinges, latches, tire/wheel brackets, etc.
In my trail rig I've actually slammed my cooler rack into a tree and suffered little more than a loss of paint on the rack, if had been the wife's stock 40 it would have crushed the rear quarter. The bottom corners of the main support tube are strong enough to fend off rocks and attach a high-lift jack.
FWIW, my cooler rack will hold Jerry cans, RotoPax or an ice chest, depending on what I need.
Tommy,
Just confirming what has been said. Don't compromise the strength of the vehicle by hanging weight where it was not designed to go. (I would include the back of the spare among those places—too much leverage.) Invest in a proper frame-mounted carrier.
Use a factory later tube tire carrier. , it mount to the left, with some simple modification you can mount the jerry can to it
Maybe this would work for you? You might be able to fit a later swing-away carrier and weld a jerry holder to it like this, with the number plate holder attached to it.
Just a thought.
i dont have a top for mine so my cans go on the side over the kick vent only photo i have on the new computor
Tommy,
Looks great, what carrier is this?
Tommy,
That was made by a company called Stout Equipment in New Mexico, sadly no longer around because their racks were the best I've seen or used. But it would be easy to have someone competent fabricate something similar.
