What should be used to plug these?Those straight thread bolts jammed in the tapered threads in the intake?
Stock hardware is still available. You can have the header flange machined to the same thickness as the intake to eliminate any spacers. Get a straightedge on the intake and use a stock or remflex gasket(a polarizing topic).Thanks for the advice. The more I look at it, seems like a leak between intake and block. What are the best bolt / stud setup for a good seal? The intake use to seal, so would sanding be needed as stated in a reply?
I like all studs & nuts and I like OEM. They're special and better.What are the best bolt / stud setup for a good seal?
I find that OEM studs are plenty long. I have run two Fel-Pro gaskets in the past without a problemIf you fix the leak with stepped washers and 2 gaskets, factory studs are too short.
I just bought thick flat washers at a bolt store and used the bench vise and a file to make the necessary corrections. Each location was a little different, that way I was dead on.Can you buy stepped washers are do you have to make them?
IIRC, the manifold studs on a '72 are a smaller diameter than a 2F, probably shorter too...So on my install the studs that were there were too short. YMMV.
I made mine (very carefully) on a bench grinder.Can you buy stepped washers are do you have to make them?
+1
