Napa part number for longer studs
#641-2196
#641-2196
the problem is the import tax... and EVERYTHING sits in customs forever, ive a friend with a cnc lathe and opening them up wont be a prop, just need the starting point...
will you be replacing the Master Cylinder, if so do you have a part number?
...some have a plastic piece with a rubber plunger of some type, if you have this, now is the time to remove it as youll not need it anymore, hence the proportioning valve that you are adding to your system....
If you are contemplating doing rear discs, don't waste any more time... Do it.
I converted the rear to discs about twelve years ago, and they're still awesome. They'll stop my 4600 lb 40 with a heavy trailer behind it no worries. Wet, dry, hot, cold doesn't matter... They work.
I used front rotors and calipers from a 77 Chevy Blazer mounted to the rear of the FF rear Hubs. I used longer studs from a 96? Toyota Landcruiser (from Toyota). Residual valves removed. Willwood proportioning valve. Custom mounting plates modeled after the original Chevy stamped steel mounting plates.
Thanks for the detailed writeup Cam.
Cam, I'm in utah want to hang out on a weekend and help a brother out? Where a bouts are you? I'm in pleasant grove. I have a 1965 so I think I'm going to need a different brake master cylinder/booster as well. I went out to start it up and saw I had brake fluid down the drivers floor board on the inside. I believe a rubber boot has decided to die this year. Anyway instead of repairing the old it looks like this is the way to go. How does early springtime sound?
I'm interested what wheel studs you used.. I have Hilux rotors behind my FF flange and front studs, but the stud shoulder is too high.. I used thin spacers to stop the wheel nuts bottoming out.. Maybe the Blazer rotors mounting flange is thicker and bottoming out is not a problem..
Cam, Been reading, and rereading...Where does the line run out of the proportioning valve? Did you run a new line to the back axle, or did you connect to the existing line? Excuse my ignorance if I missed it in this post, but I am curious...
