Impossible Steering Dampner Bolt!
Have one to sell? Sell now
Details about 5pc Tie Rod Ball Joint Pitman Arm Seperator Remover Set Pickle Fork Tool Kit
3 ratings
2 viewed per hour
| Add to watch list
Seller information
specialtytooldirect (44069 )
99.8% Positive feedback
Follow this seller
Visit store:
specialtytooldirect
See other items
Item Information
Item condition:
New
Quantity:
9 available / 1,691 sold
Price:
US $18.88
Buy It Now
Add to cart
903 watching
Add to watch list
Add to collection
Free delivery in 3 days
1,691 sold
46 inquiries
Shipping:
FREE Expedited Shipping | See details
Item location:
Meadow Bridge, West Virginia, United States
Ships to:
United States and many other countries | See details
I think you & Kevin do the same thing as far as this goes. Sounds interesting to me. Is there a thread somewhere that describes what/why/when/how y'll do this & if it's something that others can/should/need to be doing in other areas of the US?
They're in the same volunteer group and work together and such, so yes.
I know this because I work with them, too. :D
You can check out more here:
AZ- TRAL/Tonto Recreation Alliance
And here:
Tonto Recreation Alliance Forum - Index page
Get a bigger better pickle fork and a bigger hammer. I have separated several hundred with my Proto tools fork and it has never broken. Try forking it from different sides.
How's this for a giant pickle fork! I'm feeling good about this one, will let you know how it goes after a few good whacks with the hammer. I could almost even use it for my She-devil Halloween costume!!
I wish you the best of luck with your new pickle fork...
However, in reading the reviews on Amazon for the aforementioned OTC Front End Service Kit http://www.amazon.com/OTC-6295-Front-End-Service/dp/B0002SRH7O/?tag=ihco-20 I came across the following review that I found quite humorous...
1 of 1 people found the following review helpful
5.0 out of 5 starsit'll make you feel like a hero
Byundeadmouseon February 24, 2015
Verified Purchase
My buddy doubted the need for these. Determined to show me I wasted my money, he came out with a pickle fork and started hammering away on my new project: a 30 year old pick up that had never seen a single tune up in its life... I let him... and when he was tired out I walked up and popped off those rusted ball joints like nothing. Then i stood over him arms akimbo, sun at my back, wind in my hair and said: "sometimes money does buy happiness"
...sometimes it buys you a pickle fork...
It may be expensive but if you value your hands/back/sanity/emotional well being, or just wanna show off... you'll just go ahead and pony up now.
Good Luck:) Remember, you can never have too many tools...
I had a hard time with the pickle fork (worked on this piece for an hour or more), rented the below item from oreillys. came off in 1 minute or less. Bought the OTC kit and has helped several times when working on the vehicle. easily worth the money.
The first side (PS, above photo) came off pretty easy using this tool below, but no such luck on the second bolt.
I'll just point out that the above tools are not the same level of quality. OTC is well known for making really solid stuff.. even then when I used the second tool on my steering damper bolt the thing was tight enough to flex the flat part.. until I started beating on the bolt with a 5# sledge (as they are designed) and it popped loose. I can say, make sure you aren't in the way of that damper when it comes loose.. mine had some serious force stored up in the tool and hit the ground pretty hard.
Geez, what's up with the negativity on the pickle fork? It was the only tool we used in a 10 bay shop that did a few front end jobs a day to separate ball joints and tie rod ends. I don't remember ever encountering one that we couldn't remove. You just have to smack it hard. Alternating sides helps too.
There are a couple of tricks that help to separate the stubborn ones:
1. Heat as mentioned above many times. What you need to do is to heat the outer part fast so it expands before the inner part. The inner part needs to stay cool. An acetylene torch is the way to go because it heats fast. If you heat it slow, both parts expand, which defeats the purpose. In the shop one guy would be beating on the pickle fork while the other one was heating it up with the blue tip wrench. If you don't have an OA torch, you can heat it evenly with propane and then chill the inner part quickly with dry ice.
2. Compression shock. Smack the outer part hard with a hammer. This will compress the hole slightly and squeeze the joint apart. For tie rods, you need to put a 15 pound sledge behind the tie rod hole to use as an anvil and hit it with a 5 pound sledge. This works surprisingly well, but you need two people.
So the TRE tool in the first post is what I used to remove my damper when I initially replaced with factory and then when I upgraded. The trick is to tighten it down as tight as you can then hit the outside of the tool along the backside of the fork, effectively driving it forward. Then tighten and repeat. If it doesn't pop after a couple tries hit the TRE were the stud of the damper goes in while under tension from the tool. Use a 24oz or greater ballpeen when doing your hammering, don't be gentle with it, assert some dominance. Should pop.
Success! Guess it wasn't so impossible after all. Thanks everyone for the support and suggestions, I really appreciate it!!!
A few solid hits with the hammer from different sides with the pickle fork (thanks @Pin_Head) and it popped right off. The new one bolted right up and Done. So shiny and pretty....yet ruggedly handsome at the same time! Thanks again!
