Impossible Steering Dampner Bolt!
Oahu, HI
Well, what had appeared to be a pretty easy job has turned into a not so much fun ordeal that has resulted in two broken tools, damaged bolt and Plenty of frustration! Need some advice on how to get this second bolt out (the one that connects to the rod on DS).
Managed to get the other side out by using this tool recommended by a member here. But broke one of the side forks off trying to get the second side off.
The first side (PS, above photo) came off pretty easy using this tool below, but no such luck on the second bolt.
Also, my neighbor had a pickle fork tool that he tried to help me out with that also broke when he tried to remove it.
And I don't know if you can tell from the first two photos, but I damaged the end of the bolt trying to get it off, so I can't even put it back together now! Have it soaking in PB blaster right now, and will try again later today. Any advice on how to get it out?
I was going to say a pickle fork. Maybe get a better pickle fork? I know I had to beat the hell out of mine with one for 20+ minutes before it came free.
I tried every tool, hammer, puller, fork, explosives, I can buy and borrow and eventually gave up before I broke something in the steering. Took it to my mechanic and let him do it, some come easy, some are in there to stay.
I could be wrong, but does the new steering dampener not have a new bolt built into it (looks like a ball joint on the end)? I've not done this job personally, so that's just an observation from the pics provided. If yes, you can pound that bolt out using whatever force is required, as you'll be tossing it for the new one. I would have said pickle fork would be the tool for the job, but it sounds like you already broke one.
Edit: I see from some of the other pics that the bolt is separate, but you're going to want a new one from the looks of your current one anyways.
The pictured above is a tie rod puller I rented from autozone when I did my Slee lift.
Looks to me like the bolt is at a slight angle and getting held up where it passes through the hole on what looks to be the ? tie rod? If there is a way to manipulate the steering damper so that the bolt is centered in the hole, perhaps it would be easier to remove? I've never done this job myself, so take my advise with a grain of salt. If it is that hard to remove - how will re-assembly go without damaging the bolt?
FWIW, i used the tool at the bottom left corner of the photo below because there wasn't enough room to use the tool pictured above. i remember it affording me a little more clearance and better fit around the rod end.
That's the tool I used for the first side, but It couldn't get the other side off and ended up breaking off one of the fork ends of it. Maybe I will see if Napa has a more heavy duty one.
FWIW, i used the tool at the bottom left corner of the photo below because there wasn't enough room to use the tool pictured above. i remember it affording me a little more clearance and better fit around the rod end. View attachment 1154591
Thanks, do you know the name of that tool or where you got it?
Nothing I could do at home worked. Here is my saga, and it has a few tips you can try. But it took some serious tools and 2 very large guys to get it to budge.
Steering stabilizer
Ohh yea, this gave me some trouble, wasted a lot of time running around for tools.
Forgot how I got it off though, i'm a horrible mechanic, hahaha.
I would think adding some heat and continue the PB Blaster treatment would do the trick. Then see if you can return the tool you broke and get a bigger one.
I just did my suspension last weekend as well, and I ended making due with the tools I had.. I ended up using a torch to burn the rubber away and used a grinder to cut the bolt in half, and then just pulled it out.
Would it work to have someone turn the wheel slightly to take the side load off the bolt/straighten it out, so it could be hammered out?
Must've got lucky, but the I used the two prong style tie rod end puller/ball joint seperator tool. It is pretty heavy duty, but they sell them at AutoZone.
I just use a small propane camp bottle with a torch end for stubborn press fit bolts usually though. Cheap and easy, but takes a good 5 minutes of sitting there heating it.
With the style tool that you broke, once you get it good and tight, smack the hex end of the screw with a 4# hammer a couple times. The impact can shock them loose. If that doesn't get it, add heat while the tool is in place under load. Heat the forging that the tapered bolt is in. It may take a few minutes with a propane torch. If you can get it dull red, you have gotten it plenty hot enough. Tighten down on the tool some more while it is hot. It will come apart.
