Impossible Steering Dampner Bolt!
I feel your pain... I had such an issue with mine I decided I couldn't get it apart without ruining the whole Tie Rod End so I bought a new Tie Rod End and I didn't have to deal with that dang bolt again.
I think I end up using a brake rotor tool with the three claws, maybe that was for the power steering pump, growing old sucks.
Next time you want to pound on the threaded end of a TRE or any bolt, just thread the nut back on first to protect the threads and prevent mushrooming the end of the bolt.
i used an air hammer with a fork and torch. came right out. torch is the key for those.
Same here. Heat is key. Came off easily for me after the torch.
Would it work to have someone turn the wheel slightly to take the side load off the bolt/straighten it out, so it could be hammered out?
Good idea, I will try that to see if it helps. Thanks!
That's a good idea, wish I would have done that.
I used the 3/4" ball joint separator from Harbor Freight on the TREs and steering stabilizer bolts. Several of them required numerous blows from the hammer, with the separator tightened down hard. PB Blaster and a torch can be helpful as well.
Not sure if this would work, but I just recently replaced my TREs and had to use a floor jack to hydraulically "assist" them out. Maybe you might have some room to wedge a bottle jack in there?
Get a bigger better pickle fork and a bigger hammer. I have separated several hundred with my Proto tools fork and it has never broken. Try forking it from different sides.
Agreed... Also make sure the pickle fork has a wide mouth so the pressure is applied via the flat mating surfaces and not the against the stem of the bolt/stud.
So
Much
Code
:lol:
Get a lever (big solid pry bar or something) lever against it and wail on the pitman arm near the balljoint with a BFH :)
I used my trust air hammer. I was done in 10 mins. You may not have access to one so use one of those pullers to put pressure on the stud. Find a way to wack the other arm and it may pop out. Just don't hit the puller
You should do what I did. Go to Arizona and have @inkpot get it out.
Thanks, but I am out with the Forest Service again today. Busy hauling the District Supervisor (head of the whole Tonto NF) and some of his staff around in the woods to show them the really good trails we want to keep in the Travel Management Plan. They are starting to understand our appetite for "challenge" wheeling along with nice "touring" trails.
Last week we were out doing jackhammer repairs on a trail that was closed due to extreme erosion after a Forest fire. We have to do at least one more day out there before we can get it opened.
Maybe we could squeeze it in next week?!!!
Thanks for the tips/advice guys. I am going to locate some more robust tools (giant pickle fork and BFH) and get at it this afternoon. Thanks again for the help!
I think you & Kevin do the same thing as far as this goes. Sounds interesting to me. Is there a thread somewhere that describes what/why/when/how y'll do this & if it's something that others can/should/need to be doing in other areas of the US?
Same problem here a couple weeks ago. I bought this at Harbor Freight, wouldn't budge. I tried hammering the s*** out of it, nope. Nothing would work. So I ordered this kit from Amazon. This is the first tool I tried and it worked perfectly:
While I was tightening it, I thought to myself, "Maybe I should move my head out of the way, it might pop out and hit me." Right after that thought, it popped out and hit me in the upper right of my eye lol. Got a black eye, but it came out! It was the original dampener, too. But I got that bitch off finally.
