I got my new MC today and installed it, tried to bench bleed but the kit I bought only had one of the fittings I needed and there's 2 ports, so I just pushed the plunger about a dozen times till fluid squirted out the fittings, and put it on the truck. I tried using my new Motive Power Bleeder but after 20 minutes of messing around there was no fluid coming out the bleeders when I cracked it, 15psi in the system. So I pulled that all apart and had a friend pump the brakes for me. I didn't check in time and actually sucked the reservoir dry on my 4th bleeding point, so stupid. Started all over again and bled them all again. Took it for a drive and it's perfect.
The reason I mention all this, my symptoms matched yours perfectly, I F'd up enough that if anyone should be having problems it should be me, and a new MC is what fixed my issues completely. I really think that's what everything is pointing to. Atomicshawn's point about dry bleeding the MC possibly damaging it is valid IMO. Maybe see if you can get your hands on a used one to try?
