IFS Hub swap for bigger brakes
Go to my Rebuild Trusty page and I have put all my photos on there. To he honest I am not sure what the seal plate is.
It’s where the ifs hub meets the spindle
that gasket should be there and if you got a hub rebuild kit it should be in there one for each side. Or go to the dealer and get them. I also put gasket sealer on mine.
Yes. I have them, but I’ve see pics of with and without them installed.
That’s what I’m asking here…
I would suggest using the ARP hub studs from FROR Also the knuckle studs . As far as the wheel studs Agree with Cruisermatt The ones from FROR are just longer not necessarily stronger ( i belive they are from dorman )
I emailed them and they said they don’t carry ARP anymore..
A few more photos of right side mocked up for fitment. Everything is looking good so far.
Cruisermatt was right about fror’s spindle bolts and washers. The washers came apart when I torqued them to 34 ft lbs.
I would say the outer hub seal is optional. Most of the Toyota rear FF axles don’t have a secondary hub seal.
Are you able to spin the hub ? I could not use the hub seal on mine . It looks like you have it over the step of the hub ?
Yes. It spins no problem. The hub slides right into the seal perfectly.
The fror lock washers took a major s*** today. I don’t think I’m gonna use their spindle or caliper bolts. Which bolts did you use?
I have all ARP bolts Knuckle / Hub. and on my spindle i have the one from Low Range / Trail gear that does not use the washer that you have to bend over
