Im working to tune my carb again. I'm a bit confused. First I have read the FAQ and other posts on this. I have good vacuum and don't think I have a vacuum leak. However when I tighten down the idle mixture screw the engine does not die. Furthermore when I take the screw out it seems to have a slight bend in it towards the bottom. Is this right or should it be very straight? Did I bend it by tightening it down too much? Is that possible? The idle mixture screw seems to do nothing really at this point.
I have a 1975 2F.
Also I have to keep the idle RPM's closer to 800 else it will die (timing light).
Furthermore my Fj40 will sometimes die if I'm in neutral unless I keep the choke partically closed.
I have a 1975 2F.
