I need Gears!!
Spokane WA
Hey there. Does anyone on here know where I can get 3.73 ring and pinions for my 93 cruiser?
I put a 24 valve cummins in with an nv4500 and could get epic MPG if I can get the rpm down to about 1500 on the highway. I am thinking 3.73s or higher with 35 tires?
Any leads on gears that are reasonably prices would be great.
Thanks.
In Europe 3.73's came on a few diesel 80's. A few on here have got the Hp fronts at substantial cost $2000ish iirc. They are also hard to find.
Ebay.co.uk
I found 3 new sets with install kits for roughly $500 an axle
Thanks for the info. I also found a place here in wa that just recently has them on the market. Justdifferentials.com
Yes I called them. It's a new thing. There is another company here as well that does it. I think nitro is the one actually making them.
Did you get a set? Results?
That looks like a 24 valve. You do the swap? I bet that bad boy gets up and goes!
Thanks. Yes i did the swap. And yes it does go like stink! About 350 hp and 700 ft lbs of torque. My favorite part? 24mpg. :)
Only if you drive it like you stole it all the time. Im pretty gentle on it....most of the time. I have also upgraded the r&ps with heavey duty 3.54s
That is a clean looking swap. What manufacturer makes 3.54's out of curiosity? I have the same "hood strut" by the way. :D
The only place I could find them was Marks 4wd out of aussie land. Great guys to deal with. The gears fit fine but the rear pinion is a bit different than the one that comes out and requires anout 1/4 in of shim. Because the pinion is the spacer instead of having the crush spacer. Weird but it works great. The only down side is that the front and rear setup cost about 1700:eek:
Did just differentials not have the 3.73's? How is it with the 3.54's? Is low range still decent? What is your hwy 70mph rpm?
The only place to get gears that are higher for the cruiser are out of Country . I tried just diffs. With 275/75-16 i am at 1950 to 2000 with 35s it goes down to 1750. Low range is still great. I still never use 1st when driving daily.
5.61 or 6.34 1st gear?
