Yes, yes, yes.... I searched. There is alot of info out there though so i was wondering with the things i have done so far, if some people could help me pinpoint this noise.
After a good day of wheeling yesterday i noticed once i got on the highway the 80 had developed a high-pitched howling noise. Not a groan.
Having dealt with these before i woke up this morning, drained and refilled both diffs, T-case, and greased what u-joint fittings i could get to(I have a DC front shaft).
So far, none of this has made any effect at all on the noise.
I just went ahead and pulled the front shaft to see if that would help, thinking it would point to a u-joint possible. Still, no change.
The howling is effected by speed, the faster i go, the louder. Also there is a slight change in pitch when decelerating.
Lastly, it sounds like its coming below the pass. floor board but i could be wrong(t-case?)
At this point, i can only think its t-case related although i would have thought the gear oil change would have made a slight difference.
Hope thats not too much info.
Thanks
Thanks
