If you put this up on jack stands and put your head under it to listen for sounds you'd better tape it so they can show it when you get your Darwin Award
If it comes down to the hose, i guess i'll try it but at this point the sound is gone. I'm guessing i'd have to through the shaft back in to wake it back up.
Although at this point, i should probably do the rear pinion bearing and seal b/c there is obvious play in the bearing and its leaking pretty good and i might as well do the rear t-case seal and while im in there see if the bearing needs replacing too. The rear t-case output bearing can be swapped out w/o pulling the t-case which saves alot of headache.
If there is play in the rear pinion you need to check the staked nut that retains the pinion. It can work free and will cause catastrophic failures if you don't repair.
If it is tight and you still have play, you may have a pinion problem.
I would say with a leak at the pinion flange and play there, you may have found your problem.
If you have play at the pinion, that means the bearing there is worn out or that the nut backed off and it's now loose. It likely explains your noise. You need a diff rebuild and a bearing kit.
The t-case output if leaking should have the seal and bearing replaced. It's true that you don't have to drop the case, but you do have to drop the back half of it. It's the same work whether you replace the bearing or not, so just do it.
Brother Brian's howl turned out to be pinion bearings in the rear diff. We couldn't find it until the carrier was pulled and the pinion spun by hand, no play but noisy. If you have play, the gears may have issues too. His is currently resting comfortably on my bench waiting on parts.
Do what i did when i was trying to ID a noise. Put the truck on 4 jackstands with the wheels still on. Crank it up and put it in drive. Lay under it with the driveline engaged and spinning then you can really hear the problem and pinpoint it. I like this method better than a lift because technically with the wheels still on and the truck sitting on jackstands under the axles, the driveline angles are still the same as what they would be if you were driving down the road.
A local guy who is on the board now and again and helping me out with this and of course has brought up the issue of regearing now while im that far into the rear diff..
