Disconnect from the network when you run it. If it cannot check for updates, it will run something like 29(?) times with no network connectivity to phone home, then you just reset the counter in the configs when it gets to zero.I have installed this several times and I keep getting a
"Critical Update" Software is out of date as of Sep 12th 2016
You must update and every option is greyed out except update.
Any thoughts?
Thank you @getco. After struggling on and off for the past few months with different windows machines, downloaded versions and driver hell, I'm now using tech stream on my MacBook Pro and reading AHC pressures on the '99 LX. Pressures are way high which is what I expected, but I wanted to know pressures before replacing rear springs to compensate for the extra weight.
Getting Techstream up and running can be a bit of a pain. Hopefully this helps someone get started quickly.
Step 1: Purchase an OBD-II interface. Options:
- https://amazon.com/Fangfei-Mini-Diagnostic-Scanner-Toyota/dp/B06XGB714M?tag=ihco-20 ($20, Prime)
- Ship From USA VXDIAG VCX NANO for TOYOTA TIS Techstream V12.10.019 With SAEJ2534 | eBay ($79, Shipped)
- Others, I'm sure.
Step 2: Download VirtualBox for Your Operating System:
- Windows: http://download.virtualbox.org/virtualbox/5.2.4/VirtualBox-5.2.4-119785-Win.exe
- MacOS: http://download.virtualbox.org/virtualbox/5.2.4/VirtualBox-5.2.4-119785-OSX.dmg
Step 3: Install VirtualBox Software You Just Downloaded
- Windows: Double-Click downloaded file
- MacOS: Double-Click downloaded file, run installer
Step 4: Download TechStream Image:
- MEGA (V2! Click to download)
Step 5: Double-Click downloaded file.
Connect & Enjoy.
-g
I just found this thread - is Virtual Box = TechStream + cable driver combined?
I have a Mac Book Air, would you mind sharing which cable you used and which download did you work with. I would love to get this on my Mac Book
I recall a function in techstream to program a master, but I don't think there is a way to program remote functionality.Silly question - vehicle was bought with only 2 keys (are not fob-style keys - one valet, one master) - will this allow me to program a blank fob for remote access by chance? Wondering before I make my Amazon order....
OK Success! The trick appears to be to be in the early steps. Open the drivers door, close AND LOCK all the other doors with the switch and manually unlock the drivers door. Revised steps that worked for me:
Program Remote Key: FSM sequence E (1998-2002)
When doing any of these operations timing is critical – use a watch if you have no sense of time.
Begin with the key out of the ignition and drivers door open and unlocked (all other doors closed and locked).
Within 40 seconds ;
- Insert remote key into the ignition (Do NOT Turn) and then pull remote key out.
Within 40 seconds;
- Use the power lock switch on the drivers door, perform 5 (five) lock/unlock cycles starting with lock.
- Close, then open the drivers door.
Within 3 seconds the power door locks should cycle automatically indicating successful entry into programming mode.
- Using the power lock switch on the drivers door, perform 5 (five) lock/unlock cycles starting with lock.
- Insert the key in the ignition cylinder. Turn the ignition to ON (Do NOT Start) then back to OFF
- Remove the key from the ignition.
Return to step 1 if the locks do not cycle at this point.
To accept a remote transmitter perform these steps within 40 seconds;
Within 3 seconds of completing the steps above the power door locks should lock then unlock automatically. If the door locks do not cycle, your remote has not been accepted. Repeat steps 1 and 2 of remote acceptance procedure above.
- On the remote key, press the Lock and Unlock buttons simultaneously for 1 second.
- Immediately after letting go of the Lock and Unlock buttons, press the Lock button and hold for 2 seconds.
Close the drivers door. Test new remote functions.
Hi @TurbineTester,
Probably best to start a new thread so this one can focus on the narrow topic of this particular method of techstream install, but this should get you started:
Cheers,
-g
Step 1: Purchase an OBD-II interface. One option:
Connect & Enjoy.
-g
Edit (4/8/18): I removed the more expensive cable, as I received a new Mini-VCI cable that works 100% at 1/4 the cost.
VirtualBox is technology that essentially allows you to have a running computer *inside* your computer, no matter if it's mac or windows (or linux).
Combine VirtualBox, the technology, with the Software in Step 4, and you do get 'TechStream + Cable Driver'.
