FAQ How-To: TechStream In 5 Minutes
Frequently Asked Questions
@mvrx thanks for the info. Can you please confirm that the VCX Nano works with both your Lexus/Toyota Series 100 and your RAV4? Or do you use two different devices? And did you buy it from AliExpress or otherwise what are your recommendations on the best place(s) to buy this device?
My story is pretty simple. I started with a cheap Mini-VCI clone and tested it on my 2021 RAV4. It could read all the modules and clear DTCs without any issues. The real problem came when I bought a new set of wheels with genuine Toyota TPMS sensors. Every time I tried to register the new sensor IDs, Techstream would lose communication as soon as I clicked Write Data.
After digging through a bunch of forum posts, I realized the Mini-VCI clone was simply too slow and unreliable for that operation. The VCX Nano kept coming up as the recommended alternative, so I ordered one directly from VXDIAG. Once it arrived, I registered all four TPMS sensors on the first try—no connection drops, no headaches.
I can't speak for every Toyota or Lexus model since I've only used it on a 2010 Lexus RX450h and a 2021 Toyota RAV4. From what I understand, though, 2023+ models require Toyota's newer GTS+ software, which replaces the legacy Techstream platform.
I can't get Techstream to open. I'm not much of a computer person. I set up Virtualbox, downloaded a version of Techstream. Every time I try to open it in Virtualbox, it's "aborted." I get the following error codes:
Failed to open a session for the virtual machine TechStream 12.20.024.
Not in a hypervisor partition (HVP=0) (VERR_NEM_NOT_AVAILABLE).
VT-x is disabled in the BIOS for all CPU modes (VERR_VMX_MSR_ALL_VMX_DISABLED).
Result Code:E_FAIL (0X80004005)
Component:ConsoleWrap
Interface:IConsole {6ac83d89-6ee7-4e33-8ae6-b257b2e81be8}
Having the same problem here. This worked the last time I used it, nothing's changed, but now it's FUBAR.
Anyone have any suggestions for solving this problem? Free beer to the first response that solves the problem.
Seems the virtual machine may have gotten disabled in the Bios somehow. Maybe checking that would help solve.
Get into bios settings. For Intel CPUs, look for Intel Virtualization Technology (or VT-x). For AMD CPUs, look for SVM Mode. Enable the setting, save, and reboot.
I tried that, but my BIOS doesn't have those options.
It should somewhere, were you in advanced settings mode, not EZ mode?
Whats your hardware specifics, motherboard manufacturer?
Edit: If you're using Windows, this link may help
Thanks. I just bought one too. Next job is to get it all working 😊 I've read mixed reports of whether it works with my 2005 Lexus. I'm not sure whether it supports K-line protocols or not but I'll soon find out.
The BIOS setup only has one "mode"; it's either in setup mode or it isn't. Again, this worked the last time I launched Techstream, and I haven't changed anything.
I guess it's time for me to actually pay for the thing...
Is it possible to share the Win7 VM with v18?
I've actually observed the opposite. I upgraded sequentially through the versions (v7 → v10 → v12 → ... → v18), and with each upgrade I noticed additional features being added rather than removed. (BTW, if someone needs a Win7 VM with v18 or older versions, let me know)
What I still can't explain is why some vehicles don't report their VIN when Techstream performs the initial connection. This happened to me with a cheap MVCI clone on a 2021 RAV4. As soon as I switched to a VCX Nano, everything worked as expected—the VIN, model, and engine were detected automatically.
The last vehicle I connected to was a 2010 RX450h, and I had to select everything manually. I have no idea why the VIN wasn't detected. My only guess is that the ECU may have been replaced and never updated with the vehicle's VIN.
Has anyone else experienced something similar?
First, I'm apologizing in advance for the length of this post. Hopefully you see fit to actually read it, lol.
I read on a different post of yours that you're successfully using the VCX Nano. If you have the time, I'd greatly appreciate you answering a few questions about your setup. I can get connected to my 2024 Tundra, and it properly displays the VIN during the initial pop-up, and on the left sidebar where it also shows the vehicle build date. I can even the health checks, but I'm seeing some other strange behavior that's keeping me from registering a new key.
1. Are you launching Techstream using the patch that you can get from VXDiag? I chose to go the route of purchasing a key from someone who has a keygen. Since Techstream seems to start up and connect fine, I don't think this is my problem.
2. Which version of VX Manager are you running? I'm able to download and install V1.8.9.0601 just fine with Microsoft Defender running. But if I accept the prompt to update to V1.9.1.0420, then Defender goes nuts about Trojan viruses. I do think it's a little suspicious that this most recent version is not available for a stand-alone download from VXDiag and can only be obtained via following the update process of an already installed version. This is my main laptop, so I'm being pretty cautious right now.
3. Still talking about within VX Manager, what version of the Passthru and Toyota TIS "apps" are you running? VX Manager shows an update available for the Passthru app, but if I accept it then it's another spot where Defender goes crazy.
4. Switching to talking about Techstream, which VIM are you selecting? The drop-down menu shows I can select "Toyota - J2534" or "VXDIAG". I've been selecting the latter, since I'm using the VCX Nano.
5. Lastly, if you think it's vital to disable AV to get all of this working properly, what would be involved in me taking you up on your offer about a VM with Win7 and Techstream? I've never set up a VM, but I'm good at following instructions, lol.
While running Techstream, I kept getting a pop-up error telling me that my license was expired and I needed to update the VCI. I could tell this was a pop-up being generated by VXDiag not Techstream. I believe this was because I needed to update the license on the Nano itself. I've now done that, but I'm trying to iron out some of these other wrinkles before I make additional attempts at registering a key.
The other weird thing is that while trying to register a new key, I got to the point where it generates the seed codes, but weirdly the VIN that was displayed had an extra "1" at the end. I haven't run across anyone else mentioning this happening, so I don't know if this is normal or if it's the reason my key registration failed. Each passcode I purchase is $15 and is a one-time use, so I'm trying to figure this all out without burning through additional passcodes.
Thanks for any assistance or knowledge shared!
Hi Guys, may I ask, is it possible to “Bleed the Brakes “of a 1998 LC100 4.2D VX RHD Landcruiser with the TechStream program, in the same way TechStream can bleed the brake system in later Landcruisers. Thank you.
Getting Techstream up and running can be a bit of a pain. Hopefully this helps someone get started quickly.
Step 1: Purchase an OBD-II / Mini-VCI interface.
- I have sold out of my cables and supply chains are back in order, so no reason to purchase more. Anything like this will work: Mini-VCI cable on eBay
Step 2: Download Hypervisor
Step 3: Install Software You Just Downloaded
  • Windows: Double-Click downloaded file
  • MacOS:
    • Intel Mac: Double-Click downloaded file, run installer
    • M1/M2 Mac: Double-Click downloaded file, drag to Applications folder
Step 4: Download TechStream Image:
- Windows / Intel Mac: LINK
- M1/M2 Mac: LINK
Step 5: Double-Click downloaded file.
Connect & Enjoy.
:santa:
-g
Edit (04/08/18): I removed the more expensive cable, as I received a new Mini-VCI cable that works 100% at 1/4 the cost.
Edit (02/28/21): Updated links to new versions of Virtualbox & new link to cheap Mini-VCI cable
Edit (10/30/22): M1 Compatible workflow / updated virtualbox links
I'm in the same predicament as @MachineRuse. I purchased the VCXnano, but it seems I need a better version of a techstream ova than supplied in the 5 minute guide here. It needs to be Windows 7 to support my scanner. And I can't reliably get the registration to work after the first successful attempt.
For a 2024 car, I don't think you'll be able to use the Techstream v18. They switched to GTS+ (Global Techstream Plus) which requires a subscription with server validation.
1. No, I don't use any patches. I found the installation kit and I'm using this Web Page - https://tis-4bb3f0.tiiny.site/
2. I'm on v1.9.1.0420 and I had the Defender flag a dll on Win10/11 and had to allow it on the device. Nothing harmful, just a protection from the developers on that dll that gets flagged as a virus. If unsure, use this VM 2.89 GB folder on MEGA - https://mega.nz/folder/8gtjTBZZ#fmTk07oybMo0w2OkVpM-CQ
3. PASSTHRU = 04.04.240321, TOYOTA = 04.04.210328
4. I tested both and it works but I have the "Toyota - J2534" currently selected
5. I have a dedicated laptop for remote work, tools and a dual boot Win7 / Win11. Techstream is installed on the Win7 partition and works the way it was intended. While I think it's safe to allow the installation (trust the source) I encourage you to try the VM method
Regarding the license, yes it's for the VCX, it needs to be updated each 60 days and it requires you to be online.
Good luck with the setup!
It worked!!!
Your message was an incredibly timely solution to this repair I'm working on.
My details:
I have VCX nano and it requires at minimum Win 7. The job I'm working on requires that the "Utility" button shows up once you connect to a given computer in the car.
The download from the given MEGA account was very spotty so I created my own MEGA account, transferred the given folder into my own account, and downloaded what I needed from there. The ~1.3GB Windows 7 .ova was set up with all the right programs, but I couldn't get the installed techstream v18 to register.
How I fixed it:
1. I uninstalled Techstream v18
2. On my host, I downloaded Techstream v12 install exe from MEGA. I suppose I could have downloaded it within the VM.
3. I transferred the file to the VM (I use virtualbox for the VM, so I upgraded guest additions in order to create a shared folder between my Win 11 host and the Win 7 VM)
4. I installed Techstream and finished initial setup, making sure to select "US Dealer 1".
5. I made sure that the VM had network enabled and "NAT" set as the adapter.
6. In the register window that pops up, I copied the Software ID over into the web page, and used the North America key. It brings me to a website, I'm not sure whether it helped but I just selected Toyota Dealer, gave "test" as username and password, got an error message, and...
7. Looked back at Techstream and I'm registered! I disabled the network adapter at this point.
8. I made sure that virtualbox is passing through the scanner in DEVICES>USB. I have "Toyota -J2534" selected within Techstream.
Also:
I did not have to update VX manager, and currently it says "update licence failed" when connected to my scanner, yet still works. Previously I ran VX manager on the host and got the license and scanner software updated. I'm not exactly sure how this license functions.
I bought the typical china mini-VCI adaptor probably 2 years ago but finally needed to use it when the a/c quite working on the 200.
Used the Virtualbox and TechStream mega link in the first post, both are still working fine as of this post.
Running a windows 11 laptop.
Had the typical issues with Virtualbox saying "aborted" when trying to open TechStream the first time.
It ran fine in safe mode after that, but I did turn off windows firewall and defender as a few post in this thread say to do.
Plugged right in and worked fine, if you are used to any OEM style diagnostic programs it's real easy to use, although a bit clunky as expected.
For anyone trying to get Techstream working on an Australian 1FZ-Fe motor, or another vehicle that was not sold in North America, you may need to change the region within techstream, which defaults to North America.
If you follow the links in the first post on this topic, install virtual box, then download and save techstream image.
Then open it and run it.
Then, within the virtual machine, click the start button, then right click My Computer, then select Manage, then device manager, then expand network adapters, then right click the network adapter/s and select disable.
Then, click Start, then My computer, then navigate to C:\program files\Toyota Diagnostics\Techstream\Env folder.
Then right click the IT3UserCustom file and click Open.
Under Region, change RegionCode=NA to RegionCode=OT
Change RegionID to 4
Change Region to Other
(If you are from another region, put those details in there instead)
Save the file.
Then run techstream and it should hopefully work for you.
If you have already run techstream, this may not work, so I would suggest re-importing the original techstream image into virtualbox, so you have a fresh copy, then doing the above.
With my 2002 FZJ105R, originally, when I selected Toyota, and the year, the only option I was given was the 2UZ-Fe.
After doing this, it correctly saw the 1FZ, and I could read data, clear codes, etc.
It looks like it should also see older models with the 1FZ as well.
Hope this helps.
Hola buenas noches alguien me puede ayudar con esto estoy intentando programar llaves a un prius 2008 pero no me reconoce el modulo de inmovilizador porfa y a parte me sale un error que dice no se ha podido conectar a VIM
You'll need to sort out the connection the the VIM first.
Are you using the mini-VCI adapter or something else?
Sometimes simply unplugging and replugging it gets it working.
Otherwise try another USB port.
