How To: 100 Series Hood Lift Support
San Juan Cap.
Once again I looked at a few threads on this topic. Suggestions, but no pics. So here's my take on replacing the OEM lift supports with pics. Easy stuff fellas.
I ordered Strong Arm lift supports from Amazon. $35.
Amazon.com: Qty (2) StrongArm 4361 Toyota Land Cruiser, Lexus LX470 1998 To 2004 Hood Lift Supports, Struts, Shocks Cylinders: Automotive
You will need a 12mm wrench. Once again it has been provided for you in the tool bag.
You will also need something to support the hood while you work on removing and installing the hood supports.
You will use the 12 mm wrench to take off the old OEM lift supports.
Just recently did mine as well. Some of you guys got lucky who were able to just take the screws off really easily. Let's say I applied the old caveman approach after they were seized/stripped. In the end all my hopes paid off and I have a fully functional hood as well.
I was looking for this write up when I had to do the same thing on my truck last month! This should be added to the FAQ! Great job and thanks.
How do these compare to OEM?
Not sure about OEM vs Strong Arm. I guess time will tell. Inexpensive, quick, and easy fix. I'm satisfied.
Thanks for the write up. Just in time as my hood hit me in the head a couple of times working on the 100 today
Great write up!! Thx to OP - simple steps, but helpful on your first time.
+1 on the fit. I have a 2007 and they fit great.
To add on to original instructions:
1) the new ball hardware that I received used an 11mm
2) there are no tools required to fit the ball into the socket. It literally snaps right on. I was unsure at first when I was "playing around" with the loose parts before install. Once you apply pressure, they click right in to place.
PS - my local Lexus dealer (who had been great for other service) wanted $175 to replace them
Finished product:
Advertising for a solid product:
I got mine for around that price from lift support depot, and I just popped off my old struts and popped the new ones on. I didn't even have to undo the old bolt.
Sweet, I need to get on this. Have had my set of hood & hatch struts sitting on my kitchen counter for the last 3 weeks....got tired of having the hood almost take me out when I have to tinker with the stupid EFI fuse
Hiking poles, adjustable length, make good temporary supports. I also tied the hood up to the roof rack with a cord just for insurance.
I found my Hi-Lift handle fit well between the hood and fender as a support. That was a nuisance so I replaced the hood struts with the above mentioned Strong Arms. As @OG 91 LC said.... Inexpensive, quick, and easy fix. I'm satisfied.
