How reverse shackle effects value...
Prescott Valley, AZ
So my ‘78 is very original and and very good shape for not being a nut and bolt frame off as it did not need it. It came from the PO with reverse shackle front end. How would this effect the value vs. being returned to original front suspension setup? Any opinions appreciated. Thanks mud brothers and Merry Christmas!
Well I guess I am an original freak, but would also like to lower ride height as well. I realize it IS an involved, expensive project. It has an old Man A Fre 4” lift. I want 2.5 or original ride height and run 31’s
Would be really hard if not impossible to go back to original ride height without removing reverse shackle, am I right? I am pretty sure I could run a 31” tire with original ride height.
Do you have the original springs? Not a lot of springs out there at OEM height. I have OEM springs and 31x10.5” tires, so no problem there.
If you want to lower ride height, go back to stock springs. Call Cruiser Outfitters or one of the other vendors for quality stock height springs. Then decide if you want to keep the SR or not.
40 with reversal 45 without
@brian I guess I would have to reach out to another ‘78 owner to determine where to rack on/weld new perches/hangers?
Cut, grind? Mine are welded on up front....
Location is the same for at least the 73 through 78....probably the same on all years.
Originally riveted on brackets, it's not hard to see where they go.
A little grinding dirt never hurt any one, most are welded on.
I would say there is a lot more on your rig that would benefit from the time and dollars and have a greater impact on resale than taking the SR off.
Thanks @brian much appreciated! So anyone have opinions on one that is very original except for reverse shackle and how it effects value?
Check out BAT there have been a few with SR on there and no effect seen
There are benefits to both as we know. The purists will not like SO, but , that does not mean it is a bad thing. Application vs. resale maximum.
you are selling your 40 ? - if not selling, why bother about value ? :meh: - it's all in the fun of driving it, that's what makes it cool :steer: :cool:
and why would you ever want to go with smaller tires than your truck can accommodate right now ???
I don't think value is diminished compared to other things that are somewhat irreversible. My stock 69FST, except for things that I can always put back on (like the jump seats) is very stock. I run the Supertraxion 7.00-15LTSs. I think the stock height is perfect for what I consider to be a pretty stock tire setup. It fits the rig like it was intended and, with no power steering or disc brakes (which I am also fine with) it all makes sense. On the other hand, I completely get wanting it raised, bigger meats, PS, PB, lockers, and other mods and there are some VERY cool rigs by fellow MUD members which, although not stock, are awesome (and are practical upgrades from stock). To each is own and I appreciate all of them. As for reverse shackles--mehh--easy to undo and falls under the category of the "the fall will probably kill you".
