How Much for This FJ40?
Harrisburg, NC
I'm new to the forum and looking at getting a new SWB 4x4... hopefully a FJ40...
I know it's hard to tell from just the below ad and pictures, but any idea what a good price for this would be? Drum brakes all around as well as non-power steering box that has a leak. It's not local so I most likely will have to get a member of my family who live out that way to pick it up for me... basically buying sight unseen. Still looks like a nice rig... just not sure how much is a good price for it... he's asking close to $8k is that a good price??? Jeeps I can price... cruisers... no idea. Anything I should ask/look for???
Thank you in advance!!!
AD:
This was a frame off restoration about 4 years ago. The motor, trans, brakes, paint, interior and about everything else was NEW. The fellow I got it from drove it about 100 miles and # 1 rod went. When I took it apart, the motor was new, but someone forgot to tighten one of the# 1 rod bearing cap bolts. We installed a 1973 long block that was checked out, and put the brand new non-smog head off the rebuilt motor, along with the new clutch and pressure plate. It runs great now.
Some of the winch engage cables are frozen but the winches all work good. There are 3 bicycle brake like cables that could use replacing or oiling.
This FJ sold on Ebay 3 years ago for over 11,000.00. Here is what was listed as new or rebuilt:
new side view mirrors off 1974, all new wheel cylinders (yep verified),New Paint, Reupholstered seats, new floorboards, sand blasted and POR15 coated frame, Rebuilt motor (rebuilt again),rebuilt trans, new weather stripping, new emblems throughout, 5 new tires, new bat, rebuilt carb, rebuilt radiator, rebuilt brake booster, new brake lines, new starter, new rear tail light s and bezels, new winch motors front and rear, newly coated underside, new window cranks, new interior lights, new shocks,
Speedo works but odometer is stuck at 39K.
This is not a perfect "SHOW" Toyota, but it's sure a nice one. It was done by a fellow who owned a body shop in his spare time. I guess there has been only about 3 owners.
The overdrive is what puts this thing over the top. It’s a Hone-0-Drive. It does highway speeds without fearing for my life 70mph, It starts right up and runs great!
The hard top is off a newer model with the little side opening windows.
The front winch is a remote Warn, and the rear is a Ramsey. The front fenders are the only things really showing rust. I have a replacement for one of them.
Frame off 4 years ago but they did not replace the steering wheel?
New / rebuilt engine but the #1 rod went within 100 miles? If that is an indication of the type of work the po did or had done, I would wonder about the quality of the rest of the work.
If the truck does check out as described, $8K may not be a bad price, especially if it did sell for $11K 3 years ago. For all the work listed, it should be a perfect show truck.
Again, go look at it but a well maintained frame off restoration should not go down in value. Make sure that you (or whoever looks at it for you) gets under the truck to look for rust.
Good luck.
I'm with everyone else. If this rig had a frame off resto just 3 years ago and with the POR 15 , paint etc, I dont think the fenders would be showing rust if it was done correctly. I'd be weary of this rig.
I knew that looked familiar. It has a weird fixed tailgate because of the rear winch, sort of like a jeep fiberglass body and modified (read: chopped in half) amby doors.
Here's the ad from craigslist...
1971 FJ40 Landcruiser, Winches, Restored with Overdrive
I'm sure there is a mudder nearby to look at it for you.
That's the one... To be honest I think I posted here b/c something about it did not "feel right"... still if anybody is up that way that wouldn't mind taking a look at it please let me know...
why should they have replaced it ? looks just fine to me - hell, it still has the horn button (functioning?)
but, it says in the ad "motor new" and it blew within 100 miles :confused:
Come on... you don't oooo and ahhh at the sight of a 1F? I thought everybody did. :lol:
HA no I've always got the "wow that thing is old". Or the "you should put a 350 in this thing". The only oooh I've ever experienced from my 1f was when i sliced my hand on a rusty old battery tray trying to take the fuel pump off.
Hmmmm, nobody is trashing the Hone-o-Drive? I would guess a lot of
people would consider that a downer of the deal. It might work great, but there's no parts, and if it goes, the whole transfer case output shaft has to be replaced. What is IT'S history?
I would be scared to death to drive a 1971 FJ40 at 70mph whether it had OD or not. It does not handle like an M3.
You betcha, since most of the 1Fs are used as boat anchors, those were boat owners salivating at the thought of another boat mooring point.
eric:doh:
