In my Hj60 it has a small pinhole weeping leak, no problems starting/driving but with all the salad oil it swallowed the old diesel residue is fluid again and ends up in the separator and NOT in the diesel filter (never saw a flake in there).
The original is no longer available and a 5 minute fix is adding an after market filter but the glass bowl might scare some (when it hits a rock)
It is hard to find a 24 Volt WIF (water in fuel) sensor.
The OEM hard fuel line is 8 mm in diameter (.314"). 5/16" (.312")
23930-58010 W/SEDIMENTER (11/1984 - 09/1985)
or later type might be avaialble?: Toyota Landcruiser HJ75 Sedimenter assy, fuel 23930-68030
diesel filter was clean and I have a lot of filters so can change them often
(no need, never clogged, but one time the sunflower oil froze up I think)
Websites with filter info and parts:
Making Fuel Lines
http://www.mastminder.com/MastMinder%20 ... %20kit.pdf
https://www.svb24.nl/nl/diesel-filter-a ... rator.html
http://dieseldokter.nl/?product=delphi- ... opvoerpomp
http://www.nauticgear.nl/techniek-aan-b ... eider.html
http://www.exalto.com/nl-nl/parts/filte ... erkproduct
http://www.euro4x4parts.com/pieces_toyo ... ence_d_eau
I used the cheap 45 euro delphi HDF296 as replacement and just drove 3500 kilometer with it, I like the glass inspection and have one spare glass, every filter comes with new O-ring.
The sensor is 12V so not good for my HJ, HJ was packed and ready for holiday...
I really liked to have the warning light but it is useless and expensive, still I hate removing a warning light:
The sensor is 27 Volt and when the two wires are connected the filter light is on.
Tiny leak in mine:
Removed the water sedimenter, the 8 mm inside (14 mm outside) rubber hoses can be removed by hand and no tools needed, diesel starts leaking instantly.
Delphi HDF296 water sedimenter with 8 mm connection fittings (2 in bowl and 2 8mm so 4 brass fittings)
make a bracket?, or repair old one, still a cheap fix but not perfect, bowl should be filled but after starting, driving and pumping the prime pump there were no problems and it filled itself.
the sedimenter completly drained, more stuff but the sedimenter is filled and drained at the top:
Diesel residu :
The floater has a magnet and when up (floating) will switch on (make a connection)
open it up, unscrew plastic and no need to break it:
inside:
diesel In and outlet
cleaned hole:
later type:Toyota Landcruiser HJ75 Sedimenter assy, fuel 23930-68030
Now does is separate water?, it does but only "visible" water drops, the lower PPM (parts per million) is not removed aldo I like to think high PPM water bonds to visible water drops.
Non visible water is a WVO thing. link to biofuel book:
Biofuel_ebook_v24.pdf
What fun it was to be a waste criminal storing 1000 liters, don't touch $hell international chemicals and the dutch queens money
