LOADS of Toyota Landcruiser Manuals
Brisbane, Australia
Hey guys, here we have a large collection of manuals, all of which I have converted to searchable text for maximum convenience. You can browse through them online or download the entire collection using the link below:
Toyota Land Cruiser Manuals 40's, 55, 60's
I would recommend switching to "List view" (top right) if browsing online, otherwise you can hit "DOWNLOAD ALL", it will zip them up you can download and browse offline:
Additional links (feel free to post more below and I will add them here):
TOYOTA LAND CRUISER 40 55FJ40LV-KCJA - POWERTRAIN-CHASSIS - | Japan Parts EU
Cheers!
H41/H42 Transmission Manual and the 40 Series Parts Diagrams would be very useful. Thanks!
List updated!
StaleAle, I have updated your transmission manual and it now supports searchable text so you may want to re-download that one.
new45, you may be interested to know that I have discovered the two engine manuals ("2h-engine.pdf" and "2h-12ht engine.pdf") are actually both completely identical, so you will only require one or the other. They both include the same information on the 2H and 2HT.
Also, may I please ask a moderator to sticky this thread? I'm sure many people will find it useful.
What an awesome resource! Thanks for sharing this plethora of manuals. Mind posting up the F series engine and the '72 FJ40 Wiring Diagram?
You're welcome! I have just now discovered that I can upload entire files AND folders to Google Drive, so I have begun the process of batch converting ALL the PDF's to searchable text, and I will then upload the entire collection - at which point you will be able to download individual PDF's or entire folders of PDF's together. Cheers for now!
1971 FJ40 Wiring Diagram please.,
I got a hold of a CD filled with 3.12GB of Landcruiser manuals (which I have converted to support searchable text) including 40, 55 & 60 series and thought I'd share them. I will list all the available manuals here so just post which ones you're after and I will upload them for you :)
If there is enough demand for the entire archive to be uploaded I can do that too.
P.S I will be hyperlinking each PDF in the list as they are requested, so check to see if the manual you are after is already available :)
TOYOTA LAND CRUISER 40 SERIES FJ40-43-45-BJ40-42-45-46-HJ47:
| 40 SERIES DIMENTIONS.pdf
| 40 SERIES PARTS DIAGRAMS.pdf
| FJ40_b.pdf
| impco LPG MANUAL.pdf
| landcruiser82.pdf
| serie4_01.pdf
+---ENGINE MANUALS
| +---2H,12HT-1985 engine
| | 12H-T Lift_pump.pdf
| | 2h-engine.pdf
| +---B,2B-engine BJ40-43
| | b-2b-engine.pdf
| +---B,3B,11B,13B,13BT-engine
| | 3b-engine.pdf
| | B_3B_11B_14B_1988-on_engine_manual.pdf
| \---F SERIES ENGINE
| +---2F_emissions_control - parts manual-1981
| | 2f_emissions_control-1981.pdf
| | series6_2f_motor.pdf
| +---EARLY 2F ENGINE
| | f-engine-lowres.pdf
| | f-engine_wsm-.pdf
| \---LATE 2F ENGINE
| 1975 2f Motor FSM.pdf
| 1980 2f Engine LATE.pdf
+---GEARBOX MANUALS
| H140F-H150F-H151F GEARBOX.pdf
| h41-h42-h50-h55f_trans_rm.pdf
+---MAIN BODY ,CHASSIS MANUAL
| 1958-7-70_Chassis_Body_Manual.pdf
| 1971-lc_fj_chassis_body_manual.pdf
| 1975 FJ40-43-45-55 BJ40-43 HJ45chassis-body-manual.pdf
| 1980 Chassis & Body - 40-42-43-45-46-47 SERIES.pdf
\---WIRING DIAGRAMS
1971_Toyota_Land_Cruiser.pdf
1972_Toyota_Land_Cruiser_FJ40.pdf
1973_Toyota_Land_Cruiser_FJ40.pdf
1974_Toyota_Land_Cruiser_FJ40.pdf
1975_Toyota_Land_Cruiser_FJ40.pdf
1976_Toyota_Land.pdf
1976_Toyota_Land_Cruiser_FJ40.pdf
1978_Toyota_Land_Cruiser.pdf
1979_Toyota_Land_Cruiser.pdf
bj42_wiringdiagram.pdf
fj40_wiring_diagram.pdf
wiring_diagram_78_fj40.pdf
TOYOTA LAND CRUISER 55 SERIES:
| 1978_FJ55_factory_Toyota_AC_Guide.pdf
+---F SERIES ENGINE
| | F_1948-1975_engine_manual.pdf
| +---EARLY 2F ENGINE
| | f-engine-lowres.pdf
| | f-engine_wsm-.pdf
| \---LATE 2F ENGINE
| 2F Engine LATE.pdf
+---FJ55 wiring diagrams
| 1972_Toyota_Land_Cruiser_FJ55.pdf
| 1973_Toyota_Land_Cruiser_FJ55.pdf
| 1974_Toyota_Land_Cruiser_FJ55.pdf
| 1975_Toyota_Land_Cruiser_FJ55.pdf
\---FJ55 workshop manual
toy_lc_1962-1974_FJ55_97216_chassis.pdf
TOYOTA LAND CRUISER 60 SERIES FJ-BJ-HJ:
+---1986_60 SERIES maintenance_procedures
| 1986_60 series maintenance_procedures.pdf
+---aisin hubs
| aisinhubs.pdf
+---BJ-FJ-HJ CHASSIS-BODY-ELECTRICAL --1984-1990
| chassis-body-84-90.pdf
+---BJ-FJ-HJ CHASSIS-BODY-ELECTRICAL--1980
| Chassis & Body - 1980 Pub No 36044E.pdf
+---BJ-FJ-HJ CHASSIS-BODY-ELECTRICAL--1984- 60,70 series
| chassis-body-1984.pdf
+---BJ_FJ_HJ60_electric part manual
| series6_elec.pdf
+---ENGINE MANUALS
| | 12H-T Lift_pump.pdf
| | 2h-12ht engine.pdf
| +---3f_3FE_1985-1992_engine
| | F_3FE_1988-1992_engine_RM1341.pdf
| | F_3F_1985-1988_engine.pdf
| +---B,2B-engine
| | b-2b-engine.pdf
| | 3b-engine.pdf
| \---F SERIES ENGINE
| 2F Engine LATE.pdf
| f-engine-lowres.pdf
+---GEARBOX MANUALS
| +---A440F_auto transmition_fsm
| | a440f_fsm.pdf
| | ata440f04.pdf
| +---H140F-H150F-H151F 5SPD MANUAL (MORE IN CHASSIS SECTION)
| \---H41-H42-H50-H55F MANUAL TRANSMITIONS
\---Toyota Technical training Manual
01 (Electrical Fundamentals).pdf
02 (Electrical Circuits).pdf
03 (Electrical Components).pdf
04 (Analog and Digital Meters).pdf
05 (Wire, Terminal and Connector Repair).pdf
08 (Charging Systems).pdf
57 (Emission Sub Systems - Engine & Emission Systems).pdf
62 (Emission Sub Systems - Evaporative Emission Control System).pdf
65 (Emission Sub Systems - Secondary Air Injection).pdf
AIR FLOW SENSOR.pdf
BATTERYS.pdf
CATALYTIC CONVERTER.pdf
CLOSED LOOP FUEL TRIM.pdf
CLOSED LOOP.pdf
COMBUSTION.pdf
COMPASITORS.pdf
COMPUTERS.pdf
DIGNOSIS.pdf
DISTRIBUTER TYPES.pdf
ECU OUTPUT.pdf
EFI 2.pdf
EFI 3.pdf
EFI 4.pdf
EFI.pdf
EGR.pdf
ELECTRIC CONTROLED TRANSMITION.pdf
ELECTRICAL COMPONENTS.pdf
ELECTRICAL TOOLS.pdf
ELECTRONIC TRANS DIOGNOSIS.pdf
elecTROUBLE SHOOTING PLAN.pdf
EMMISION.pdf
FUEL SYSTEM.pdf
IDLE AIR CONTROL.pdf
IDLE SPEED CONTROL.pdf
IGNITION 2.pdf
IGNITION.pdf
INJECTOR DURATION.pdf
INPUT SENSORS.pdf
KNOCK SENSOR.pdf
MAP SENSOR.pdf
OXYGEN SENSOR.pdf
PCV VALVE.pdf
PRESURE SENSORS.pdf
SENSORS AND ACTIVATORS.pdf
SHIFT INTERLOCK.pdf
SHORT CIRCULT FINDING.pdf
SPARK ADVANCE CONTROL.pdf
SPEED SENSOR.pdf
STARTING SYSTEM.pdf
TEMPATURE SENSORS.pdf
TPS SWITCH.pdf
TRANSTORS.pdf
Thanks for all your efforts!!:clap:
If possible can you post the 1974 FJ40 wiring diagram? I'm troubleshooting a complete electrical failure, and it would come in handy.
All PDF's are currently being uploaded to Google Drive! Refer to the original post :)
I will update once this process is 100% complete.
Awesome. Thank you for doing this...it an amazing resource.
