yes upflow and possibility to attach the barrels together with standard industry stuff.
I wanted 10 barrels but it was already chrystal clear non water that came out.
Rain and weather proof, rodent (mice) proof and industry standard was goal.
Better to burry barrels in sand to prevent quick temperature changing from side to middle of barrel starting unwanted flow of oil.
Stuff freezes so needs 3 degree environment.
The barrel with 3 white 25 liter (1 micron!) filters was filled above filter sock level and filters 60 liters at a time (75 max), when full pump to valvoline and fill again.
I am now moving to another farm and sold the whole circus to a guy that wants to go off grid.
One micron is 1/1000 mm. The human eye can see dust particels about 25 microns in size. A hair is about 70 micron.
0.1 tot 0.3 micron = house dust
0.3 tot 1 micron = tabacco, metal fumes, bacteria like staphylococcus
1 to 5 microns = Bacterien and small dust.
5 to 10 microns = pollen, mould, dust
10 microns = big dust particels
Dont know if the links work but it is a lot of chemistry in that little water separator jar:
Measure of density of oil and water mix with aerometer range from (g/ml) 880-0,940g/ml
With eatable oil the factor is 6,8 ! wvo= 913-925 kg/m3
If colder the aerometer will float higher!
by a temp of 20o Celcius 0,9190 kg/m3 and with n15oCelcius 9190+(5*6,8)= 0,9224 kg/m3 if higher temp minus l*6,8
---------------g/cm³--kg/m³
Water (liquid)--0,998--998
Glycerol-------1,26---1260
Lijnolie--------0,94--940
Petroleum-----0,8--800
Diesel---------0,84--840
Engine oil------870--940
sink=better lighter fuel
float= bad, water!
aerometer online sale: http://www.labowebshop.nl/areometer-typ ... /itm/18158
Density list in Dutch: http://www.aquafix.nl/bestanden/afschei ... tabel2.pdf
http://www.elsbett.nl/index.php?id=57&L=7
You know this site:
http://biodiesel.infopop.cc/eve/forums? ... 2#38010602
An easy way to filter WVO
float= bad, water!
You know this site:
