Hood hinge bushings?
Yes
Door Hinge Bushing & Pin Kit
That ain't a hood....
I used door busing but had to drill out the hinge to fit the bushing in. The pin was the same size,but there were no bushings in the hood hinges on mine. the hole was too small for the bushings. I had to cut the flanges off the bushings in order for the alignment to work. Hood doesn't rattle any more :)
Nocents
ah haa ahahaaa
thats good.
spit mtn dew on my keyboard thanks texx:flipoff2:
i need to rebuild mine but i could not get them apart so i gave up pita
LOL Texx. BSEvans - thanks for the info though, I may need to rebuild those as well at some point.
I may take the hood hinges apart and try to size up some nylon bushings locally. May try bronze as well?
Sorry, brain fart. I could not find replacement pins and rebuilt them with metric SS socket head screws and SS nylok nuts. I used the same nylon bushings you can get for the other hinges. I do not have a photo of the hinges but do have a photo of the rear door hinges utilizing the same solution.
Something else you might consider. I believe you could make hood hinge pins that you could use, if you took the SS hinge pins used on the other hinges and cut the side of the pin with the head off leaving the length of the original pin. I would install them smooth barrel first and then press the knurled end in. You might need to enlarge the inside ID of the hinge barrel in the middle to accommodate the nylon bushings. I did not think of this solution until this thread.
Or, if you're a cheap bastard like me and the truck's already painted...lay a piece of 5/8 heater hose in the drip rail at the windshield side of the hood..end of rattle. Okay, mine doesn't rattle, but I once had one that did. :)
