hi beam indicator
spicewood,tx.
my new to me 75 fj40 has a problem. this hasnt been street legal in 12 years- old deer lease truck. anyway, everything worked at inspection except for the high beam indicator light. after tearing apart three times, come to find out that even tho the bulb shines you cant see it in the blue plastic indicator.
what now? i am using a #158 bulb as was what came out of it. do i need another bulb? or is it only supposed to show at night?
nedd some help here as it will not be road worthy without a sticker. well that is to say legal. rides like a bitch now. has not moved in two years--square tires, original shocks,you get the idea.
oh, by the way, any suggestions on replacement shocks for a stock suspension?
thx, jim:beer: :beer:
even at night, the high beam indicator would be called dim at best :rolleyes:
shocks: search for Romer's post on Bilsteins. I really like the ride since I got them. New bushings made a huge difference, too.
Jim, many of the blue plastic lenses have become so opaque over the years that they will hardly transmit light. If it is required for you to pass inspection, I would drill a hole in it large enough to let you see the bulb when it is on. Once the plastic has become cloudy, I don't know of anything that will bring it back.
GL
Ed
Mr. Toad said:
You could knock out the blue lens altogether and replace the 158 bulb with a blue LED bulb.
Now there's an idea. And a good one at that, provided you have that type of bulb socket. Mine is too old to have that bulb connection. It would also require removal of the instrument cluster which is pretty easy. The only reason I suggested drilling a hole was to expedite the inspection process.
I'm going to pull my instrument cluster to replace the speedo cluster, so I'll do the blue LED thing then. I have a later wiring harness to cabbage a socket from. Thanks, MrToad:)
Ed
thx all.iguess i will drill a small hole per degnol. dont know if it needs to be a colored lite or not. the whole assy. is pretty to remove, just be sure to disconnect your battery first.
jim
I use L.E.Ds on all my instrument lights. I had issues seeing the hi-beam indicator during the day but who runs there light during the day? LOL. The L.E.Ds solved that problem.
jim
If it needs to be a colored light, get some lens repair tape. If your state is picky about the COLOR, then pack up and move! Next thing you know, it will be illegal to be drunk in a bar;)
Ed
good info on the leds. might go that route the next time im in there. for now just to get to pass, i pulled the original blue thingy and placed on the inside of the hole a piece of blue plastic off a tupperware type container. (it was her idea). looks really good. not original, but good. also a good opportunity to paint the the gauge cluster. jim
