The Grimm Jeeper site doesn't have any motors listed. I'm guessing that is because there are far too many different motors, versions of each motor, etc, to be able to list them all. Each transmission, transfer case, and rear end has specific gearing. If you are planning to use more custom gearing you have the option to input that gearing. With motors there are just too many variables.
Before you go very far with that site you need to know what the torque curve of your motor is (the RPM where it runs most efficiently), what your normal highway speeds are, or what other kind of use there will be if that will be more than highway use. Does your motor have good low end torque, or does it run better at higher RPM's, etc. Just what is the full RPM range you expect to normally use? This is especially important to know for diesels as they will run better, more economically, within the top of the torque curve. I'm not as familiar with how the torque curve effects a gasser motor, and it's optimum RPM range. Maybe someone more familiar with that question can chime in on that.
Don
