Fall will be winter soon. I've run without heat (or minimal at best) for three years. It's my dd in the Wyoming winters. That means when it's 30 below out I drive with my window down and sunroof open so my breath won't fog the windows.
Moving on; cause if you don't know what that's like you have to do it to understand. Scary part is I'm used to it.......
Here are the issues, what I've done, and what I'm looking for. As my issues seem to run the gambit- I'm hoping for a decent "heat" resource thread if we have enough info.
But first: throw some cold icewater down your pants because that's what warm coffee becomes after 12 seconds on January third.
Issues
1. Wiring was "toggled" when I bought it. After a donor switch was installed it ran for all of three minutes and smoked some wires. Although I eventually moved on and found the source of the smoke/smell I still ran that winter ghetto style with a new and improved "lighted" toggle switch (I did add a fuse and relay though).
q-
1. Is there a three speed switch available that will work and isn't 30 years old?
2. Is there a rectifier/reducer/transducer (whateveramahickey) available to bypass the cracked ceramic fan speed block I'm running now?
2. When I replaced the motor I found my airbox in deplorable condition. Given the availability of parts I cleared off the old duct tape and gave it a "new" round.
q-
1. Do all fj's run the same internal squirell cage set ups, and do the fans/blade angles spin in the same direction?
2. Is there a better donor option to up the output?
3. Although it hasn't really been an issue thus far I'm guessing that when my fan does start pumping air it has NO hope of ever reaching my toes or drying out my floor (heaven forbid I gain my defrost
). I assume everyone has the dry rot problem.
q-
1. Is there a retro/restore kit around that has the hoses and the elbows as well?
2. Since I'll no doubt go through two years of denial before swallowing the dollar amount for the answer to #1; is there a "cheap" way to go about it for a temporary fix?
4. Now that I've done all this the pig gremlins will have called in the heavy hitters (as I should be gaining an upper hand at this point). After the glycol green napalm scars my legs I will need to know a few things.
q-
1. Is there an aftermarket heater core out there?
2. Can I add rear heat, and is there any option newer than j/y parts (conversion vans etc.)?
5. Now that the whole fam damily is toasty warm I sure would like to see out my rear window.
q- Anybody solve the rear defrost scenario? Tape? Heater fan?
Much oblidged for any tips, help, info or .02 anybody has on the topic.- Josh
Issues
q-
q-
q-
q-
