Gotten lots of quotes, but never pulled the trigger. They have a good reputation here and elsewhere on the intetwebz.
Hey Tank, you still have the heater core?No problem, if you change your mind later send me a pm.
Hey Tank, If you can. Will you get back with me on the heater core. I'm interested.I still have it but I am not at home. I will be back Sunday. Do you just want the core or the whole housing it is fitted in? It is free only difference it would make is shipping.
Will this Part number work for a 94 1FZFE?amayama is showing 1 in stock, I would try and grab it.... part number
87107-60130
When i looked up that part number the Toyota dealership info list P/N 87107-60130 as For Primary HVAC. Land Cruiser. Front. From 01/1990 to 08/1996 so yes it looks like it would of fit your 1994. Problem is, this thread is going on 3 years old, and that heater core/part number is long since listed as discontinued/NLA.Will this Part number work for a 94 1FZFE?
Can you explain what steps you took to make a 96 heater core workthe heater core for your 1995 cruiser is discontinued. but I believe the heater core for the 1997 changed part numbers and I believe is still avaliable. That core will work also but you need to get another pipe that connects to the core.
what did you end of doingHello everyone, I am a newbie to the site.
I have a 95 fzj80 and am needing to put a new front heater core in it.
It started out slow but now my floor board is soaked on passenger side.
My question is can I get a factory Toyota core or is their a reliable after market?
What symptoms are you having?Can you explain what steps you took to make a 96 heater core work
It is producing inconsistent heat. I had a shop flush and flush the system it at times puts out very hot air but also produces very luke warm air. Will continue to live with it. Thought it is a time consuming task. Thinking I might drive it some more then flush the system again. Who knows what the previous owner ran itWhat symptoms are you having?
The are a few aftermarket front heater cores available (no Toyota ones), but to replace it you need to disassemble your entire dash. This is not a small undertaking. You want to make sure you have all the parts you need prior to starting.
Otherwise you pull your existing one and have it rebuilt at a radiator shop for about $300. Takes about 10-14 days to have one rebuilt.
Our trucks are reaching the age that we will start seeing more failures of these due to debris and poorly maintained cooling systems.
It's a solid 8 hours to remove and about 10 hours to reinstall the dash. Some can do it in less, but that's because they've done it before. You must be meticulous about bagging and tagging
Or get out your checkbook for about $2000 of work to pay someone else.
Inconsistent heat like that indicates an air pocket.It is producing inconsistent heat. I had a shop flush and flush the system it at times puts out very hot air but also produces very luke warm air. Will continue to live with it. Thought it is a time consuming task. Thinking I might drive it some more then flush the system again. Who knows what the previous owner ran it
