The supplied harness is for a two headlamp setup.
what is this kit sell for ?
I know this is the 70 section but according to those directions above, would just the harness from this kit work in a certain 4 headlight land cruiser?
Thanks, just curious based on those directions. Ok back to 70 series, sorry for the diversion!No. One could tweak two or these harnesses to work with the FJ62's ground switching system buy even at that it wouldn't be with the time/cost over an IPF upgrade harness imo.
I thought this is interesting that your High Beam indicator no longer comes on. I'm in the process of getting a BC provincial inspection (terrible) But I have Trucklites in my BJ74 and have the same problem...No indicator. I'm wondering if I can switch back to stock headlights for the inspection and that will solve the problem or if there is a fuse or bulb I can track down. Did you ever solve yours?I stand corrected .. the non-heated ones I found now are $169 .. I found a place showing the heated ones for $249 but they are out of stock.
I run the non-heated and the only issue I have is that the high beam indicator does not light up, but these are bright enough that one does not need an indicator!
Problem Solved! I just had to switch back to stock bulbs/lenses and my high beam indicator has returned! Phew!I thought this is interesting that your High Beam indicator no longer comes on. I'm in the process of getting a BC provincial inspection (terrible) But I have Trucklites in my BJ74 and have the same problem...No indicator. I'm wondering if I can switch back to stock headlights for the inspection and that will solve the problem or if there is a fuse or bulb I can track down. Did you ever solve yours?
Did you buy the hella bulb or the whole headlight for the bj74?I put the H4 90/100 in my BJ74. They were a nice improvement, and low cost
Hey brother,
I actually used different ones that a mechanic friend made for me so I can’t help sorry..Hey brother,
I ended up getting Stedi headlights with additional canbus module. High and low beams work but the module was making lots of noise so I turned it off. The module was hot after. Any suggestions? Thanks
YupI actually used different ones that a mechanic friend made for me so I can’t help sorry..
Are those the Stedi ones?
Currently running these on my BJ74, I want to put led bulbs in but don’t know which ones to get. Have you done this upgrade ?Koito iterations are available and you can remove 12v bulb and put whatever style of 24v bulb you want.
Direct fit.
View attachment 1836514 View attachment 1836515 View attachment 1836516
The Grote ones snap right in the place of the old headlights. 5 minutes per light.Currently running these on my BJ74, I want to put led bulbs in but don’t know which ones to get. Have you done this upgrade ?
Before you buy anything, here's a good video comparison between quality and garbage 7in headlights.
i see the link when quoting, but no link in the postFor those having issues with the Toyota switched ground and getting LED headlights to function properly, this $20 kit should solve your issues. Amazon product ASIN B07Q1G4LRJ
