Head Gasket Problem
Bozeman, MT
Ok so I need a head gasket for my early model f engine, and it is discontinued. Toyota doesnt have it, their system doesnt even go before 1969. However if I can figure out which part # it is they can look of the system an in other countries and whatever. They gave me 2 possible #'s 1111560010 and 1111560020 but they werent sure which it was. So I need to figure out which it is. $OR doesnt give toyota parts #'s so they werent any help, I'm hoping one of you guys out there will maybe know, in particular Mark. Heres a link so you can see a pic of part of the gasket the holes have a flat side which is why later gaskets dont work. Thanks for the help.
https://forum.ih8mud.com/showthread.php?t=59969
Here are the ones I have:
11115-60010 58-12/67
11115-60032 1/68-9/73
11115-60033 9/73-1/75
11115-61010 1/75-8/87
11115-61030 8/87-8/92
Hey Richard do you think that the F motor could be out of a 25?
attachment.php
Might be a shot to post this in the 25 section they might know more if I'm correct.
Last time I needed a gasket for a pre-'68 I wound up getting a head set from SOR. I haven't needed many parts for those motors so I haven't search for sources.
Mark...
well in the 25 section they say it's a Head Gasket 11115-60010 but that doesn't make sense to what curt said. Unless 25's were made from 75-87. Maybe the used the same head gasket but that wouldn't make much since either.
Kurt could you look at what you have and see if it maches to his Pic?
wouldn't your engine have some markings on it identifying what kind of block it is. Those numbers after the f part have to mean something. you could always call SOR they have a good knowledge of that stuff. just an idea
Chuck it doesnt matter if it was made in 58 or 68 they are all the same during that period. So I don't really care which yr it was made in. I just need the gasket for it. I noticed that when Kurt posted 11115-60010 is one of the 2 #'s Rick gave me and he said they were both discontinued and for the early engines. So I wasn't sure if Kurt mistyped or something. Kurt could you check that. If thats the right # I can have toyota try and hunt it down for me.
clemson55 said:
... I noticed that when Kurt posted 11115-60010 is one of the 2 #'s Rick gave me and he said they were both discontinued and for the early engines. So I wasn't sure if Kurt mistyped or something. Kurt could you check that. If thats the right # I can have toyota try and hunt it down for me.
I will check my stuff in the morning, the 60010 is one of the gaskets I stock and sell quite a few of, I am 99% sure that is is the 2F one. Stay tuned... :D
Rico I wasn't talkin about the numbers on the engine for the year but for the type of engine it is. Whether it came out of a 25 or 40 like Marshall said, if you could eliminate one then that would help the search . What are the head gaskets you have sitting in your garage for? How off are they? I have a head gasket for my f engine, not sure if it'll fit but when I get home I can bring it over. And yes it is in the house so you can't just go over and get it...lol.
chuck, I don't believe it matters if it is out of a 25 or a 40; the head gasket will be the same........from years 58-67 which covers both the 25 and 40.
Plus I highly doubt it is out of a 25, those things are about as rare as hens teeth
Thanks Kurt if 60010 is one you stock and sell a lot of it cant be right. Because this is listed discontinued everywhere.
Chuck dont challenge me, that would be cool though I can compare it with the one I pulled even though I highly doubt it is correct.
Have you checked with marksoffroad? :D
He has one but he wont sell it to me. He said he feels its in his best interest to keep it for himself since he has 3 of the early f engines. I'm hoping he chimes in with a part # for me.
I can understand hanging on to it, if you only have one.
I am curious to know if anyone has used the later F-head gasket in this sutuation, there is very little difference in the shape........ I believe Mark said he had heard of this being done but he wasn't sure.
So any one know if the late model F-head gasket can be used on an early model F engine???
clemson you need to order the valve re-grind set the part number is 04112-60062 this is for the pre 68 135 F motor. I got one about 2 mo. ago so i know that they still have them a toyota. it comes with an intake gasket, valve cover, HEAD GASKET, and t-stat housing
no, they are vary different i have 2 sitting by my side right now.... when i go to work i will take a pic.
oh ps i have an un-used gasket set for the 135 in the shop just incase :flipoff2:
