backfiring
Bozeman, MT
Ok so I thought I had the bugs out, put in a pc valve made sure the dizzy had vacuum got everything hooked back up. But I drove it around and its still backfiring at high rpms and it still doesnt accelerate real well because of this. I still dont have the exhaust hooked up properly because the studs are stripped some and I can't get it to seal well until I get some new ones. Do you think that is enough of a problem to cause this or other ideas?
Particularly valid if you have the backfire when letting off of the gas. I had a severe leak at the exhaust manifold and it consistently backfired when de-accelerating.
If yours is backfiring when driving at a steady speed, I suspect that there is something else causing the backfiring.
What studs are you talking about?
Ones in the exhaust manifold that the head pipe attach with?
Ones in the head that hold the manifolds to the head?
I adjusted the valves last week when trying to get all the bugs out. And then adjusted them again after driving it a bit so they should be good. The dizzy is vac advance and the line runs to the carb. I'm about to grab a timing gun and try check it. We are about 650-700 ft above sea level here. But if we go to the mts nearby which I do then as high as 6000. I'm talking about the studs which come out of the exhaust manifold which the exhaust pipe attaches to.
Your welcome, I just adjusted the timing and the idle speed and the cruiser seemed to be running fine sitting in the driveway. I left it to sit for a min and it just slowly got worse until it stalled out. Now I can't even get it to start again.
Ok so after a little break to clear my head I went back out and got the cruiser to start again. But it is barely able to keep running. Its on like 2-300 rpms and just barely able to stay running and then it usually dies out after a min with a large puff of white smoke coming from the carb. I tried to adjust the dizzy while it was running and it doesnt really change anything. Barely makes any difference to the rpms even. So I dont have a clue now. Any suggestions?
Ok so I just rechecked the points gap rechecked the valve clearances tried adjusting the fuel mixture and idle speed and no luck anywhere around. The dizzy still doesnt seem to be effecting the idle at all either. Some give me some ideas here, Thanks.
have you done a compression check? Something is wrong man. Is your dizzy shaft tight? Swap that crap out for an electronic setup from a 79 or newer carb'd toyota.
Is your compression good? You may need to drop 60 bucks on a top end gasket set, pull the head and investigate if compression is wierd.
Man you have some wierd issues here. I though it idled ok, now its puffing burned oil and can barely idle? May even have a cracked head...or gasket issue.
ragman
alright I am Clemson55's roomate and have been working with him on this for a while now...... I just wanted to clarify that when he says back firing it is shooting exhaust and fuel vapor out the top of the carb. not back firing out of the muffler. I assume this makes a difference in the diagnosis????
I had a simiar situation on my 2F a while back that was due to a cracked rocker arm. Which leads me to believe that something similiar is causing the valves to open and close at the wrong time. And we have adjusted the valves multiple times, so they should be out of adjustment. What do you guys think.
check the spark plug wires...are they going to the right plugs? I hooked up two backwards on a buddys vehicle and did the exact same thing....pull them all and start over....
do you have a dwell meter? could the distributor be 180 out?
just a couple of thoughts
bk
Sorry about being unclear all it has done is backfire out of the carb so I didn't think to specify that over the exhaust.
Dizzy is right as I said it was idling fine and got to about 30 earlier in the day before it started backfiring out of the carb. I havent touched spark plugs or wires since I put new ones on like 2 weeks ago and they were on right then.
I agree with a compression test and vacuum test, if you can keep it running.
Do you have fuel in the carb window?
uh oh....not another V8 vs. 2F debate again....lol.
I bought a toyota - not a chevy. flame on....
But yeah, we need compression numbers. Also, have you shot brake cleaner or soemthing around the base of the carb with the engine running to check for vacuum leaks all around? What about your booster leaking?
ragman
