Has anyone debaged their 80?
My 80 series is stock, and I can't really afford to do much with it but I want to do some stuff to make it mine.
I want to take the running boards off (If someone could link me a guide I'd be appreciative)
and I also want to take all the badges that aren't the "LAND CRUISER" one on the back off.
Anyone done that? Does it look good? How do you get the residue off afterwards?
Use a very thin cord to take the badges off.
A rubber wheel in the drill will remove the residue but go slow.
I thought you meant douchebagged your 80. There are some of those.........
Rebadged......
I really thought you meant removing the air bags.
Debadged .......damn autocorrect.........
the left side toyota emblem will leave 2 holes . here's mine debadged (removed the landcruiser badge too) when it was repainted to help give a visual idea to your question
I took my running boards off. I started by unbolting the middle two bolt pairs on each side and then I got sick of that and used a saws-all to get the other brackets off. I thought it was much easier to work up there with the boards off. I am going to bolt new bolts back into the holes though and cover them with a thick layer of grease so that salty water doesn't get in there and make things rust out from inside.
Be warned that when you do this, the fender flares on the front will look a little unfinished. I couldn't live with that so I had to take a second mortgage on my home to purchase a set of front mud flaps that look much better to me than without and they keep salty crud from accumulating. Some people have cut the trim pieces that used to fit against the running boards down and that looks OK too and it's free, which is nice.
Is there anyway to take off the running boards and be able to put them back on? I'm not sure how long I'll have the cruiser sadly, and I'll want to put them back on when I sell it
Several nuts and bolts under there if you look. The hardest one is on the front. It takes some patience or a gear wrench. All in all, about an hour on each side if you have NO MECHANICAL ABILITY. Look all around the running boards and remove bolts attached to the body of the truck. The other bolts, attached to the running boards, will hold everything in place. After removing, you can run the bolts back into the body. When its time to replace, back out, and put the running boards back on. This is a :banana: job with basic metric wrenchs. Heck , you could use the wrench set located in the back drivers side (US spec) tool roll. Good luck, you will like the look and ground clearance much better.
I put a sticker over the holes on the back. No one knows my "4 Runner" is really a full grown Land Cruiser.
Removing the sliders is a 1/2 :banana: job. You can borrow your wife's tools from the kitchen to do it.
Use good strong fishing line to get off any adhesive attached badges, like those on the rear lid. "Floss" the adhesive out. 25 pound test worked well for me. When I used that rubber wheel on my paint to get the adhesive residue off I kind of fried the clear coat and it left some unsightly marks. Kind of a bummer, but I'm trying not to be OCD about it.
Yes, removing the steps is a :banana: job, UNLESS the PO wrecked it and had a body shop weld hardware sideways and every which way under there to get them to stay on. I had to use a sawzall to get mine off. Mine can never go back on without significant amount of work.
Ouch. Welded things should be sturdy sliders and not the stock running boards.
