David1947 I was looking for shots from your install??
I have not installed my H55F yet. I am just trying to plan everthing out and make sure I haven't overlooked something or considered all options. Once I start I don't want to say "Oh poo" I need "X" and it is NLA
I was able to source a complete support assembly for a 40 series from GermanyWhat will you be using for a cross-member?
It's called the propeller shaft dust cover, and consists of multiple parts:What is the correct name / part number for the "cage". If putting a H55F in a 40 and installing a DC driveshaft would the cage be advisable? Or just overboard?
40 series 5 speedFrom a 40 series 5 speed or 4 speed?
I wonder why the difference? Mounting location on the transmission?It's called the propeller shaft dust cover, and consists of multiple parts:
Note the differences between the 4-speed and 5-speed applications.
what was odd is, the 40 series with 4 speed did not come with the double cardon front shaft
60 series up to the switch to the long trans did come with a double cardon front shaft.
no idea why, the distance seems to be fairly close between the transfer and front diff.
Sure they did on the some late model long wheel base 40 series. Those picture ares from a transmission/transfer case from a 84 HJ47RV from Australia. I looked it up and both double Cardan and no double Cardan were used.
anyone have the actual toyota parts numbersIt's called the propeller shaft dust cover, and consists of multiple parts:
Here you go:anyone have the actual toyota parts numbers
Thank you....all my searching and I can't remember coming across 7zap. And of course .....NLA
