The 17748 is on the way, should be here tomorrow or Monday. I will update! Good info, thanks everyone!
Any fitment issues with the #17748 on an 04 LX? I'm assuming no, but wanted to see if anyone had input.
From muffler to rear did you stay at 2.5 inches?Just to be clear the #17748 is a weld-in muffler not bolt in.
Factory exhaust is 2.25, correct? No loss of back pressure issues going up to 2.5 muffler back?Yes, just cut the old out and welded in the new.
Taking @abuck99 's advice I went the Magnaflow route. An 11" case is available - part # 12586 - you can get on Amazon for around $100. My installer is charging $175. Not bad considering the OEM would cost $430 before install.
Good from a mechanical perspective.
In hindsight I would have forked over the cash for OE.
@scwill and I find that these drone at idle whenever the truck has some load on the motor - fans to combat heat / air conditioning specifically. I have to put it in N otherwise it drives me nuts.
@LandCruiserPhil I know this is an old thread, but I am considering purchasing the Walker #11748 just as you did and deleting the resonator. Probably an ignorant question, but why can't I just clamp it on with some adapters/reducers and adjustable hangers?It been a little over a year since my exhaust upgrade.
Its been perfect upgrade in terms of sound, clearance, and performance.
Today I put the replaced muffler and deleted canister to the test. A friend with the same year and set up as mine decided to line them up for the test. The only difference was my friemds LX470 has 70K less miles and 100% stock exhaust. We did 2 test one from a dead stop to 70mph and the other a rolling punch. The LX470 with the exhaust mod easily pull the other through the complete RPM range on both runs. On the 0-70 run I was 2-3 car lengths ahead at the end.He said the exhaust made the engine sound strong and seemed to shift earlier.
Bottom line need/want a little more go and stay wife approved change your muffler and dump the canister.
