I have seen an aftermarket product for this but never seen/heard of anyone trying on mud on their 100s.
If there was ever an aftermarket mod/thing to attempt messing with OEM environment to resolve I think it has to to with the pressure valve in the tank. Tanks with CC's have a pressure valve that will shut off if too much pressure for CC to handle and then it forces the "secondary system relief point" (in this case our gas caps) to vent....short story the gas cap venting is technically "intended" as the pressure needs to release somewhere. Theres a post/thread out there somewhere that explains all this.
Unfortunately, which is why our thread here exists, the secondary control here isnt safe, sucks to deal with when you are trying to wheel/have fun/camp, and you dont want to worry about blowing yourself/rig up in middle of nowhere!!
Also unfortunately, I dont know enough on how one could override that pressure valve (I could even be getting the terminology wrong on the valve name here) and force the CC to do "more work" and how viable or potentially even worse/more unsafe that may be. But it's something to think about for anyone who may know more on how to approach an aftermarket fix/mod like this.
I think the heat shields are a waste of time and this pressure valve is where the potential silver bullet fix may lie. My gut tells my the valve in overengineered by Toyota to probably shut off sooner than needed to be conservative, as is the case with most of the overbuilt parts on these LC's/LX's!
Interesting point about pressure relief.
I have a couple 3 seater PWC's that have 16gal fuel tanks... and I usually store them completely empty, or completely full.
After noticing the tanks being pressurized over time, or when the skis get hot, I would check on them every few days to open the gas cap and relieve pressure. (these dont have any fancy valves to relieve pressure... and some are known for busting fuel tank seams)
Anyway, my fix for this was to acquire spare gas caps, and put a fitting w/ a 4ft clear hose (so i visually check too) ending with an aluminum one way check valve.
Now, in storage, I never have to worry about a pressurized tank, and if they vent, it would be very little by little. Point is to never let them got to higher pressures.
When I ride, I simply swap the vented gas caps for the original caps. Whether inside a garage, or outdoors, the vented fumes are never at a noticeable level.
-That being said, Im wondering of ways to maybe let the factory gas cap vent safely, (maybe manually controlled)... perhaps a manual valve? when and where we want it to vent.
So... we're not venting next to a campfire, or stove... etc.
-Or Maybe a gas cap w/ one way check valve could work at high altitudes? venting little by little and never getting to the higher pressures? You could even vent the cap, and maybe capture the fumes elsewhere? ... but I'm thinking the factory emmissions checks wont like that... maybe throw a code/CEL? Anyone ever drive w/ gas cap off and get a CEL?
I think you guys are on my wavelength when it comes to this problem. I think the purge function is under-utilized in these vehicles and the gas cap safety release is both semi-unsafe and activated too easily. I envision an aftermarket approach to be to add a tank pressure sensor and a relief line that's opened with a pressure switch.
1. Tap into tank - perhaps with a simple T into the line that goes to the CC system.
2. Monitor pressure and find the problematic pressure.
3. Install a pressure switch that triggers an action (12V for instance) just below the problem pressure.
4. Install a valve (basically VSV) that opens when supplied with 12V.
5. Run this vent line either to atmosphere, or ideally into the same line that feeds the engine with CC vapors so the vapors can be safely burned in the engine.
Possible switch: https://www.mscdirect.com/product/details/31043326
My 99 had this problem occur once or twice, but my 06 hasn't had any issues. Once my 06 has this happen, I'll start down this path.
@Joe422 @savirc I just realized my 06 DID have this happen last year. I took a picture of it. Dur. This is why I take pictures, I guess. I'll order up a pressure gauge and experiment with this over the next wheeling season.
