Now Colin, there you go thinking outside the box....
I really think the 80 is quite capable of producing low boost without changing over to standalone. The real advantage to standalone is the limitless power, and limitless tweeking of the tables. It also takes out the MAF which *can* be the restriction in HP (I don't think so for a low boost app). The downside to stand alone EFI is that you lose knock sensing capability of the stock truck, which I find a useful safety feature on a boosted engine. Here, I really think the OBDII boys with datalog function can tell us enough about the air/fuel system and FTU response to enable us boosted boys to put in the proper tweeks.
If we have some baseline numbers of MAF and Injector Pulse Width, we can reverse engineer what exactly the FTU is doing (or would do with a change). With these numbers, we can also match fuel injectors and pressure to meet the needs of the FTU. From my in depth look and measures so far, I only see a couple hiccups to this being straight forward.
1) The 1FZFE uses a fuel pump resistor. I suspect it's for low rpm, and maybe just for idle, and I also suspect it might even be eliminated with a properly set RR FPR.
2) The OBDI trucks (93-95.5) with AFM will either have an easier time or a much harder time getting the 4-5000rpm fuel correct. It might be easier to give that high boost high rpm function fuel assignment exclusively to the load based RR FPR. Then again, if the voltage output of the OBDII MAF isn't maxed out at high rpm (I suspect not), then it really doesn't matter to the computer if you boost the truck or not, it's looking for MAF input with injector output up to the 5volt value of the truck.
3) SC vs Turbo. I venture that the SC will be easier to tweek and tune, since the onset of boost is faster, and it's linear rpm vs airflow requires less correction. I'd certainly put forth that a pre OBDII truck will be easier to tune with an SC, since it can't measure increased aiflow over xxxxrpm (a known issue with a vane type AFM).
One of you boys with OBD II readers can help, SC or stock truck.
MAF values vs rpm
injector pulse width vs rpm
Max values of each
ST
