- Thread starter
- #41
Before I put further comments forth, let's identify the two types of EFI systems on the 93> 80 and 100 series trucks. Prior to 96(93>95.5), Mr. T used a Bosch type L Jetronic system. This includes the use of a Air Flow Meter (AFM) to measure airflow. With flap angle and air temp (sensor is inside the AFM), the computer can calculate the Mass of Air entering the engine.
96> trucks switched to a Bosch LH Jetronic type system. This basically replaced the AFM and ambient temps sender, with a Hot Wire venturi Mass Air Flow (MAF) sensor. This caused less restriction in the measurement of air, and it was a more accurate measure since it measures air density, the computer isn't calculating it.
I will split off my referencing these systems as L-AFM and LH-MAF, since some of the more technical issues and 'fixes' may apply to one or the other (sometimes both)
LT: I understand you feel rising rate FPR isn't the way to go, but you might also want to consider that every single factory turbo or supercharged vehicle uses a rising rate FPR. The reason for this is that it's a MAP (manifold absolute pressure) based measure of *load*, and much more accurate really than a reference tabled measure of load.
Dan: It appears you are lean. First, I'd ck to make sure that your fuel pump passes the resistance test, then I'd check your voltage at the pump (and your battery system voltage). Many times system pressure reductions are present when it's actually a voltage problem (lots of audi CISE-III experience talking). I'd also make sure that the WOT switch circuit is working properly, and that the switch passes the resistance test (IME 3ohms or more resistance in WOT switch affects WOT operation).
Second, AFM really only measures to about 3500-4000rpm, after that the flap is open, and the fuel is delivered via tables, so the AFM can't measure 'additional' air above 4000rpm (hmm sound familiar?). Put another way, all air flow over 4000rpm is the same to the AFM. The computer then only looks for 5 volt input switch from the AFM (AFM is wide open), and it goes to the rpm vs injector duration tables.
An excellent candidate for a rising rate fuel pressure regulator. Since you don't have the ability to change those tables, a fixed duty cycle vs rpm will deliver more fuel with either a larger injector, or a rising rate fuel pressure regulator. Since larger injectors have no 'tuning' ability, the BEGI RRFPR is a better choice, and you will need it whether you add injectors or not IMO/E. Get it first before you work with injectors. Ditch the methanol, you shouldn't need it.
Colin: I have several applications of Javad Shadzi's 034 running around, and worked with him on the very first CIS turbo to EFI turbo conversion (his system was originally designed for CIS non turbo to EFI turbo). The problem I have with it is no knock input. Actually that's the problem with all aftermarket EFI systems IMO. Now, I understand that someone close by you has cracked the motronic code to eliminate the MAF and convert it to speed density. That leaves all the safety features of motronic intact. A big development in EFI tuning, IMO.
Right now, my suggestion to anyone looking to add more fuel under boost, is to get the BEGI rising rate FPR before you spend a penny on any other piece of hardware or software. Even if you choose larger injectors, without FTU software tuning ability, the only way you will be able to dial in those injectors for on boost *load* is via fuel pressure. This comment applies to both L-AFM and LH-MAF toyota systems.
ST
ST
