I'm more convinced than ever that approaching this from a TUNER point of view is coming at it from the wrong end.
I've had several offline discussions, working towards getting some understanding of how fuel systems work. I'm more convinced than ever that approaching this from a TUNER point of view is coming at it from the wrong end. I believe that's because EFI fuel systems are not understood well here. To that end, let's try a different perspective. Let's try using the OBDII to understand the fueling needs of the truck just from the FTU, not from any ascribed expert.
A couple of simple things first. On 96> trucks, if you put in forced induction and you didn't pop a CEL for Long Term Fuel Trim (LTFT), the fueling needs of your truck are within the factory spec of -0- +/- 15%. That simple. What do you need to do to ck exactly what the LTFT is?
In the measuring block values of your OBDII reader, find LTFT (bank 1 and bank 2) and datalog their values. Whatever you do to the engine, it will result in a change or adaptation to long term fuel trim. If you turn up the fuel pressure regulator for instance, your long term fuel trim values will start to go negative, up to -15% without a check engine light. What this means is that the baseline fuel is being trimmed back. Once you have exceeded -15%, your light will kick. Conversely, if you turn down the regulator pressure, your trim values will go positive which means that the baseline fuel (fuel injector duration or duty cycle) is being increased, again up to 15% before CEL.
Again, if anyone is running OBDII with forced induction and there is no CEL, fuel is within the factory spec of 0 +/- 15%. Those with the ability to get LTFT values, should post up that data. I urge you folks to get this data before you change hardware or softare of any type.
My intent on these threads was never to flame, only put forth that the accepted theory and practice of EFI is well documented. Regarding OBDII, just about every system runs the same way in terms of FTU INDICATION of the realities of your mods. Once this data is out there, there are ways to use it to solve some of the fueling system issues that may or may not be present.
SUPRA Fuel Pump Concern
In the meantime, I encourage someone that has a Supra fuel pump to measure the return line pressure of the Fuel Pressure Regulator. I've thought a lot about that mod, and it concerns me that folks are seeing benefit from it without the FPR. That's an indication there is a backup of pressure in the fuel pressure return line. Since that line is very small and usually contains a lot of plastic line, it can't take a lot of pressure...
Next up for discussion might be the MAF, and what it's values mean in the A/F mix.
Hope this helps from a different perspective
ST
