Fuel Filter Modification Video
BenjaminCA
Oroville CA
Website
www.youtube.com
Took a crack at the “fuel filter mod” commonly suggested for the FZJ80. Since it’s kind of a pain to get in and out, this might be helpful to some. Or, solid bathroom fodder if you get bored.
I've replaced mine every 100k miles (4 times) and never had an issue with it.
Simply crack the banjo bolts, then use a super long extension to get the mounting bolts from the bottom.
A fuel filter mod I'd really like to see would be the use of a threaded port banjo bolt to add a Schrader valve and hose extension with a bracket mounted under the hood so you can connect a fuel pressure tester and use the pressure release to easily fill jerry cans in an emergency.
A great idea
Cut the Filter with a Hacksaw after it dries a few days.
Filter at 200K Miles had Very Fine Silt it in. Unsure the Source.
G darn you! I was planning on hating you last night…I passed by cause I was drunk and didn’t want to call you a grifter, then I watched your video. Today I’m drunk again and I’m trying not to like you but you’ve already make a hitler joke and referenced a Star Wars monster and said retarded… now I just wanna be friends…..subject to change 😘.
Edited :
Your lady questioned the fact you were pulling the new fuel filter you just installed and scoffed. She made the right call, you should listen to your lady.
Where the fugkq do you buy square bottom sockets Canada? Disappointed in how many caulk extensions you had to use the please your 80’s gas chamber filter.
