Fuel boiling issue
Denver, CO
I’m trying to diagnose why the fuel is boiling in my carb.
Context:
- ‘78 stock 2f
- carb heat shield/insulator installed
- fuel lines insulated
I suspect that the problem may be with the heat control valve (or lack thereof) in the exhaust manifold (part 62 and related in the appropriate year tab here: Land Cruiser 1968-8/87 Manifolds).
Can anyone tell from the pic if I’m barking up the right tree? This is looking at the exhaust manifold from the front of the engine.
Edit: Sorry, I think there was a server issue as I was posting below and the text did not initially make it.
This probably doesn't help you, but I don't seem to suffer from any fuel boiling problems (SoFL heat). In my setup below (sans JimC carb) I've installed 3FE headers. The removal of the direct contact between the intake manifold and exhaust manifold has to help. I suppose if I had too, I could also wrap the manifolds. Anyhow, if nothing else helps, it may be a possible solution if your setup is beyond repair. 3FE manifolds are cheap. They just need a bit on grinding and a new down pipe setup. One of these days, I'll measure the intake temp below the carb at full heat soak and see what I get.
Full disclosure: I've got a heat sleeve on my fuel line, and I run 100% gasoline. No carb fan...
Again, if nothing else works...
Do you have a fuel return line in the system?
Are you sure it’s actually boiling out? It can also be “wicked” out of the idle circuit and cause hard starts due to flooding. Tons of threads here on it.
Answering questions:
Carb fan:
I took it out because it wasn't functioning. It's on the list of projects to figure out unless I make the switch to TBI. Even if I do go TBI, I think I would need to figure out if the heat control valve is working to avoid excessive heat.
Fuel return line:
Yes. It is also insulated.
Is it actually boiling?
I'm sure that it's boiling because I can hear it boiling and see it through the window in the bowl. It's also hard to start after it gets to operating temp and then gets shut off. Lots of vapor lock-y behavior until I get it moving. Not sure if it's the breeze that cools it down or if it's the cool fuel being pumped in (or both) that clears it up. I'm also afraid that it's going to die every time I come to a stop light.
I wish that fuel was being wicked out through the idle circuit. That's another problem that I'm having with the carb: The idle circuit doesn't work.
Where is all of the heat coming from? Are you sure your cooling system is up to par?
I don't have a return line, no cooling fan, no real overheating problems with my carb.
Block off plate on the flapper in the exhaust manifold, non US carb, de smogged, recurved dizzy, cammed 2F.
@@rkymtnflyfisher
Cooling system seems to be doing its job. Shot various parts with the thermometer gun and readings are what you expect - 190-ish on the head and thermostat housing.
@@JohnnyC
I rebuilt the motor this spring. Manifolds were removed from the head for the operation, but not separated from one another. I'll see if I can see a crack.
If there is no crack you definitely should pull off the down pipe and look up there...
You said it was off... I take it you don’t have any pics of the parts off the motor and can’t recall if there was a flap right?
Did u do the work or a shop?
Nice. I was actually thinking about just installing headers for exactly this reason. Thank you.
I think I figured out the issue. As suspected it seems I don’t have the flap in the exhaust manifold. Those bolts on the side (see original post) are just plugs.
So next step:
What’s my best bet to resolve? Looks like sourcing the flap and associated parts might not be an option. I like the idea of using a 3FE exhaust manifold. Any other header recommendations?
I'm definitely intrigued. I'll do some googling, but I'll also take pics and/or hints on this "bock off plate".
Looks like you live in Denver. Altitude exacerbates vapor lock. I use non-ethanol gasoline and it helps. To some degree, it’s just part of carbureted engines in summer, particularly at elevation.
Electric fuel pumps can really help too.
