Frame rivet removal
Maple Ridge, BC
I'm trying to remove my steering box mount, and have ground the heads of the four rivets holding it to the frame. I've tried punching them out with a hammer, a bigger hammer, a slege, heat, and WD-40. Is there a secret way to getting the rivets out, or do i have to beat on them harder?
I ground them and then used a big punch and beat the piss out of it. You can also drill a hole in the rivet like 1/8" and its suppose to help, My .02
During installation, the rivets take on sort of an hourglass shape. They are in there pretty tight. I grind the head off, then drill out about 1/2 of the rivet to the depth of the hole it is in, then punch them out. They punch out pretty easy once drilled. Just take your time and don't break a drill bit in there.
Good Luck.
When removing my shock mounts, I resorted to cuting the corners off across the rivets, after I had cut the heads of the rivets off, then I beat on them with a hammer. I used a cut off wheel on an angle grinder, it went fast. When I removed my spring hangers, with the intention of reusing them, I drilled the rivets after I ground them down, first about 1/8", then 3/16"s, I was abel to drive them out with a punch then. Can't see reusing or selling my steering box mount so it will come off like my shock towers when it's time comes.
Did the same thing. I thought puching them out would be easy. Boy was I wrong. Ended up doing this. Took 5 minutes.
I tried an impact hammer and it didn't even budge them.
And drilling the side ones would be easy but the bracket makes it impossible on the top ones.
Air hammer - and not some little pink panty one you get at Sears - a big mean one.
Wear ear plugs.
Hi All:
Awe, Toyota rivet removal! Been there, done some of that! ;-)
If you just want to remove that steering box pedestal and don't need the rivet holes for anything grind off the rivet heads, then beat on the steering box pedestal with biggest "BFH" you've got! Drilling a hole into the old rivet definitely helps to get 'em to release!
it has been a few years since the Saginaw PS swap on my FJ40, but I think I just used the BFH and maybe a pry bar to get that old steering box off of the frame.
Good luck!
Alan
Seattle
Cool, I'll drill a hole in the rivets tomorrow, and try punching them out, I'll also bring home my air hammer. I'll let you know how I do.
too tall said:
I bought a plasma cutter for removing rivets from cruisers.Works better than anything else I've tried.
That probably involves a lot less profanity than any other method suggested, except of course when I look at the price of one. I can imagine some of the guys hearing it from the women in thier lives when they tell them what they paid for it too. If Harbor Frieght had one for a hundred bucks though, I'd be all over it.
After smashing my thumb while using a punch on a rivet that wasn't budging much, I tried a rod left from the driveway crew. The rod was about 30" long by 3/4" and I sharpened the point on it. No kidding, five taps and the rivet popped out. The extra mass of the rod made the rivet removal a snap. Plus, the rod is so long, it sticks way above the booster/master cylinder, making the top rivet removal super easy. YMMV
Here is a quick lesson in how rivets work. From a guy whose been pounding rivets in aircraft for 25+ years. A real misconception is that the heads of the rivets are what holds things togeter. In all reality what happens is that when the rivet is set(smashed) it swells and completely fills the holes in the pieces being joined. This is why just grinding off the head is of little use. Your best bet is to grind the head and using a good drill bit of the same size as the rivet driil the remaider of the rivet out. You don't always need to drill completely through. Drill a bit and try driving it out with a hammer and a punch. If it won't come then keep drilling and swinging.
You can hold dry ice against the structure and rivet and let it get good and cold then bang that bitch out of there. It shrinks the metal and will loosen the grip on the rivet. That's how we remove axles from aircraft struts that are pressed into place. It works and it isn't messy.
Grind off the heads and drill a hole, only needs to be a 1/8-1/4" into the rivet. Moderate hammer and a decent punch will pop em out no problem. The torch works too, but that is too messy and more work if you actually want to keep any of the peices. Don't over complicate this unless you have lots of free time and need a work out with a BFH.
Well I got them out, real easy. I drilled a 1/8 hole through them and punched them out. I can't believe how tight those were though, good ol toyota.
