FJ80 3fe new guy with issues
Yeah I'm not an expert but it sounds like it could be salvaged to me or just used untell you get a new head. I'd try to find a good machine shop and have them look at it and tell you if they can polish it out
So super late update but here it is. My head ended up being good. I took it to a shop that specializes in land cruisers and they took good care of me. I required 11 pins in the number two cylinder. Ten valves were leaking out of the 12. One valve was replaced and the oil galley plug was drilled and taped with a set screw installed. I had the injectors cleaned. Two were dead unless they were wide open so those were replaced. It runs much better now but I’m still a a lack of power. I can’t get it to complete a full cycle for each gear. If I stuff it from a stop it stops climbing speed and rpms around 3200 rpm. I have replaced just about everything on this turd other than the low end. My compression is good and the tsp is now brand new and replaced. My idle and timing is on point. Tomorrow I’m changing my fuel filter again because my vehicle sat for 7 months. I’m also pulling the fuel pump to inspect the pre filter. While do this I’m blowing out all the lines to make sure nothing is clogged up. Hoping for the best because after this it’s back to the drawing board if I don’t get some headway.
That sounds like mine when I the timing backed way to far off. If just would not rev passed a certain point.
Frank
It revs when there is no load. But under load at WOT it just stops climbing after 3200rpm. Like it’s not get fuel.
Plugged cats??
No cats. Timing is good and vacuum
Leaks are no where to be found. Steady idle and no CEL.
Fuel is a likely culprit.
I hope so. I’m running out of things to fix or replace. I have had it for a year and I have only out 2k miles on it. I saddens me lol
Waiting on my parts. They will be here in the afternoon tomorrow. Then We will see.
I bought my 80 about a month ago for 6500. I took it out for a drive know there were issues with it but being that it was in decent condition and it had the "bullet proof" 3FE I decided to pull the trigger. On the way home I noticed on hills that it would down shift and fall flat on its face. Complete loss of power and speed and rpms would slowly fall until I released the accelerator and let it up shift and slowly depressed it again then I would slowly gain speed. It made my 2 hour drive in stop and go traffic very frustrating to me. So I did what any smart gear head would do and went to the forums to read and learn from the pros. After hours of researching and reading I thought I had a solid idea. I just moved to Dixon California so I'm currently limited on funds until I get my money back from my move. So after testing everything I can think of and adjusting everything accord to the FSM I have gained a bit of power back on the top end and it runs smoother but when I stuff in to the floor it takes forever to gain speed and it feels as if there isn't enough power to get it to shift to the next gear. This is the work I have done and things I have found in the follow order.
1. Replaces cats
2. Inspected and replaced anything that was "tuned up"
3. Tested and tuned the TPS
4. Tested and cleaned the ISC
5. Removed and Cleaned the entire EGR system. with a possible pin hole in the egr valve its self but im not sure nor can I find a used one in my area.
6. Replaced the EGR modulator
7. Corrected and replaced vacuum line routing plumbing to include the valve cover and intake tubes along with the tube that runs from the ISC to the intake.
8. Adjusted valves according to FSM
9. Replaced valve cover gasket
10. Replaced PCV and Grommet
11. New 02 sensors
12. Checked spark plugs (which were brown) and verified the gaps
13. Timed it to 7 degrees of advancement
14. Changed oil and checked the coolant.
15. Changed fuel pump
16. Changed Fuel filter
17. Changed the fuel pressure regulator
18. Checked the vacuum pressure and I'm getting 18 psi at idle and wide open after it stabilizes.
19. My fuel pressure is right around 38 to 39 psi and holds steady.
My next steps are to adjust the transmission cable running to the throttle body and replace the thermostat due to it taking longer than what I deem normal to heat up. I still have a high idle with the timing set to FSM and the idle screw all the way in. I have built a few other rigs to include my FJ cruiser so I feel someone confident in diagnosing an issues on a vehicle until I bought this turd. The only other thing I can thing of is a slight exhaust leak and every time I go to fill up the pig I hear a lot of pressure coming from the gas tank. It runs smooth but something is still wrong and I cant find the underlying issue. Im not 100% if my terrible mileage of 9.5 MPG is an indicator of anything. I just figured that was normal for a gutless engine with a tank built around it. Its also sitting on 285 70 17 10 ply mtrs with a slee rear swing out and ruff stuff front bump I believe with tools/ recovery gear and an on board air system I have recently installed. Any ideas or leads would be amazing! Thank you ahead of time guys and I cant wait to hear back from you![/QUOTe
I had allot of the same issues, did everything you did, it ended up being the charcoal canister. There is a auto zone part from some other car that worked with minimal modification that was like under 60 bucks. Do a search on charcoal canisters ih8mud and you should find the part number.
Thanks
Just FYI, don't inspect the fuel pump sock/pre filter, just change it. This part is about $7.00 and is the culprit for most fuel delivery issues.
That’s what I’m waiting on right now. It will be in today at noon. I think it costed me 12 after shipping. I’m excited to change it.
This is my supply line. This maybe my issue?
Oh btw the way this is on top of the fuel pump
Echo that. I had intermittent issues with starting. No rhyme or reason. Came to find out that the wires running from the outside of the tank to the fuel pump had been rubbing on the fuel pump assembly. I replaced the pump, re-did the wires AND shrink wrapped them to avoid future running. Haven't had an issue since. I went through everything.
So I fixed the collapsed line for my pressure to the rest of the system from the tank to the engine and it runs perfect. This entire time it was a damn fuel line that had been kinked.
