Next step was to install the rotor housing onto the front half of the pump body. When I disassembled it, the diamond shape indent was in the orientation as shown, but I have no idea if it matters since it appears to be a mirror image.
Following that, I installed the rotor, and the vanes. One end of each vane is rounded off, and is the side that rides against the rotor housing walls. Keep in mind that the rotor vanes wear in to the rotor in the direction they were originally installed, so make sure the wear marks are oriented the same direction when re-installing. Check a few for clearance, if you have a .0015" feeler guage, which is what I recall the clearance being?
After that is done, slide the largest o-ring over the rotor housing, so it seats on the front half of the pump body. My oring was slightly loose,so be careful when mating the two halves of the pump.
The rear rotor plate has two o-rings, a large one thats obvious on the perimeter of the part, and a smaller one in the smaller short little nipple on the back.
My camera crapped out after that shot, so I dont have any more, but its easy from here on out. Place the front housing with rotor assembly in a vise with the oil seal pointing down. Place the rear rotor plate over the pins on the back, and rub a little ATF on the two orings. Place the large spring over the nipple on the back of the rear rotor plate, and center it. Take the rear half of the pump body and slide over, carefully getting the orings in position. make sure you dont pinch the main o-ring that seals the two halves together...
After that, take two bolts and lightly cinch the pump halves together using the bottom bolts, Install the new oring on the reservior and seat the reservoir. Install the upper pump body bolts through the reservoir mounting tabs, and evenly tighten all the bolts. Lastly, install the two small reservior bolts and you are done.
Make sure you clean out the fluid reservoir, mine had lots of gunk in the screen I didnt want to introduce into my rebuilt pump and steering box or the hoses and cooler.
View attachment 391844View attachment 391845
