FJ40 Wiring Diagrams
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
To lazy to buy or download an FSM or open up your FSM or PDF well then I have some pictures for you. I cannot confirm they are 100% correct but then again your probably to lazy to care.;)
And if someone wants to upload these to mud please do in a post below. I'm too lazy to do it.
1970
1971
1972
1973
1974
1975
1976
1977
1978
1979
1980
Note the pictures of a couple of harnesses linked in my sig
I have a 77: anyone know what the Green/Orange wire on the turn sig goes to? No mention of that one anywhere on the schematics, so far as I can see! It is close to the GL & Gy, which I believe are the turn lights.
I’ve definitely been all over those schematics, which are awesome. Still confused on the solid green wire out of the hazard and the diff between GO(orange) & GR which are not explained. I saw one vague reference in a painless harness hazard switch that says to splice the GO somehow with something that was also confusing, because this GO wire is such a mystery. Here are some shots of what I’m talking about, coming off both switches:
I just got done removing a 7-pin trailer harness and on my 70, the GO goes to drivers rear brake/tail lamp on our rig. I don't have a GR wire, nor 6 pin harness, just 4 pin harness. Hope that helps.
Edit: I just found this link that may help more.
Tail light wiring
Thank you guys!!
I got em working! Re-did the wiring to clean up potential problems there, rebuilt the hazard switch, which was ridiculously easy, and then found that the hazard flasher in the EZ harness is wired backwards. Fixed that and am off to the races! Now it’s time for the wipers, lol!
Not to revive an old thread but I am looking at the rear section of a 1976 FJ40 wiring harness and I am seeing a blue wire that runs from the brake light connection to a bullet connector. I am completely lost as to what the bullet connector side of this bit of the harness connects to. Anyone have any ideas?
