Hi folks. New member, first post...
I recently acquired this 1970 FJ40 in trade. Seller had little to no real info on it so I'm starting the process of trying to sort things out. The engine has been swapped out for "a 350... or maybe a 327?" Having never really worked on Chevy V8s I can't ID by site.
It starts and drives. Fired it up for the first time yesterday and noticed a pin hole leak in the upper radiator hose. I removed it a few hours ago and noticed FUEL FILLER HOSE stamped on it. Huh. Ran the ASE number and it comes back as a marine fuel filler hose. 2" inner diameter. That seemed odd. Removing it only added to the WTF'ness as the radiator was spaced with more rubber UNDER the upper radiator hose:
This... I guess "spacer" had yet more rubber under IT:
The thermostat housing looks like its set up the same but I haven't cut off the "spacer" yet:
Has anyone seen anything like this before? Seems like a fair amount of effort to use the wrong 2" hose- unless it was intentional for some reason that I can't fathom.
Coincidentally I am going to the marine supply tomorrow to pick up some boat parts so I could easily replace the pinhole with another marine fuel supply line if there's some advantage to this?
Thanks in advance for any input or comments (helpful or comedic).
Drew
Drew
