Build “Yukon Jack,” the 1977 FJ55 (Build Thread)
Where the prairies meet the Rockies
Well, it’s finally time to start a thread documenting the resurrection of this 1977 FJ55 that I bought sight unseen a couple of years ago. I found this truck on Kijiji for $2000 (Canadian $$, that is), the only glitch being that it was located in Whitehorse, Yukon, which is *very* far from my hometown in southwestern Alberta. Luckily I was able to arrange an affordable ride on a fellow’s step deck trailer, and so after a few weeks it was plopped on my driveway. I immediately started using it as a portable storage unit, and as a result it’s been sitting around for a couple of years, full of junk and miscellanea.
( Yukon Jack is right at home in the snow.)
Anyway, the upshot of all this is that I haven’t really ever taken a close look at the rig. I know there’s some rust and dents. I have noticed that it leaks oil from everywhere. I can see that someone’s made a nifty rear door in place of the tailgate window. But that’s about it.
Until today. Today I hauled out all of the junk that was in there. Much of it went in the trash. Some went for scrap. Some was added to a “free” pile in the alleyway. Finally, the only thing left in the truck was dirt, and lots of it. So I broke out my little pressure washer and gave the thing a good bath, inside and out, and I discovered that under the grime is a pretty solid and complete little Pig!
Here’s some pics.
First impression: Pigs are neat! Lots of cool little design elements that I hadn’t expected: things like the spring loaded jack handle clips under the rear seat, and the cool rear seat release, and the cute little vent control knob under the dash, etc. I’m excited for this build!
Here’s short list of what’s needed:
- Rust repair (rockers, wheel arches, lower quarters, 4 spots on the floor)
- Dent repair, passenger side quarter panel
- Rear window mechanism (glass is good)
- Swap front doors (I have the correct doors for the year)
- Mechanical stuff, knuckle rebuild, etc.
- Seat reupholstery
- Other stuff I don’t know about yet.
I’m planning to document this build on YouTube, so I’ll post up here whenever there’s a new video. Hope some of you will follow along as I try to learn everything there is to know about the Iron Pig.
Maybe consider sharing in the pigpen. Lots of knowledge down there and focus is on the Pig!
Either way these are so cool!
Welp, I got the Pig moved into the garage just in time for our first snowfall of the year. A few friends were going to help me push it in, but a couple of them bailed last minute so we ended up pushing it in with the 40 series, which worked great. I backed it in because my plan is to attack the body damage to the right rear quarter, and backing it in puts it near the workbench and in the better light.
Annnnyway, the first thing I did was remove a bunch of lights and trim. I’m missing the right reverse light lens, and the lower reflectors are intact but the surrounds are rusty. Same goes for the license plate lights. Side markers are in surprisingly good shape, and the taillights are serviceable, though one has a few hairline cracks in it. Got them bagged and tagged to make life easier at reassembly time.
Since the tailgate was staring me in the face, I started taking it apart next. It’s a little dented and the lower corners will need some rust repair, but nothing too serious. By the looks of hinge bolts, I think that the biggest challenge is going to be removing the door. I’ve started soaking them with PB Blaster, but when the time comes I think it’s going to be a Herculean battle.
I also noticed that what I believe to be the tailgate torsion bar is broken? Is that what I’m looking at here?
Since I clearly wasn’t going to be able to remove the tailgate today, I decided to have a go at the power window mechanism. I pulled it out, removed the motor assembly, and cleaned and greased everything. The plastic drive gear shows some cracking, but seems to be intact. Fingers crossed.
After cleaning and greasing:
I also spent some time cleaning out the inside of the door cavity. Amazing how grimy things get when you have no seals or gaskets anywhere.
Came up pretty nice, though! So far I’m having lots of fun with this old Land Cruiser.
As mentioned above, I am making some short videos about this build. This one is of my first walk-around. I’m far from a professional actor or videographer, but feel free to check it out if you have a few minutes to kill.
Yep, that's the torsion bar. A real PIA to replace, without it the tailgate will take two hands to lift and close. That cracked plastic window gear won't last long, there are still some printed reproductions out there, probably should replace it before putting it back together. Those license plate lights where also used on a lot of Toyota cars of the same era, look for those in your junkyards.
Starting right in on the rust and dent repair on Yukon Jack. First up is the right rear corner, which was crunched up pretty bad.
As you can see in the photo, it was pushed in on the side and also from the back, creating a pretty tight pinch where there should be a nice smooth corner. After a couple of half-hearted attempts at pushing the panel out from the inside, I decided that my best option was to cut out the whole panel so that I could repair the dents on the bench. So I marked my cut lines with some tape and excised the back third of the quarter panel.
I used a variety of mallets, hammers, dollies, etc to smash the panel back into shape. With my sandbag as a backer, I was able really wail on the thing, pushing out the dents from the back side and smoothing the crumpled steel with an appropriately shaped dolly. It didn’t take too long to get it back into a reasonable facsimile of the factory shape. A couple more hours with the dolly and English wheel and it should be close enough that a bit of filler will have it looking good as new.
The above is just a rough test fit, but it’s already looking much better!
With the quarter panel cut away, I got a pretty good look at some of the other rust repair that awaits me:
It looks as though the bottom of the d-pillar will need some attention, along with the bottom of the inner quarter and the last inch or two of the inner fender. I’ve done a similar repair on my FJ62 (in fact on my 62 I had to fabricate new inner fender panels from scratch) so it should be pretty manageable. Of greater concern is the area around the rear body mounts: it’s very rusty in that spot so there isn’t much information left about how it all goes together. I need to go study @kelly saad FJ55 thread to see if there are any clues I can glean from his epic rebuild.
Anyway, that’s all for now. More updates soon I hope.
This piece goes in the corner where yours might actually be gone. It attaches to the bottom of the apron and then the corner of the quarter attaches to it. It's a crazy shaped part. Just in case this piece on yours is rusted into pig heaven, and you don't have it, this might help you understand what is supposed to be there. It looks like it isn't there anymore because it appears that your apron is gone on the end also. Im making something else to fit into the void once it is on a rotisserie.
View attachment 4229301View attachment 4229302
Thank you for this, sir! The pic above, coupled with this pic (which I shamelessly copied from your build thread) gives me a really good idea of how the rear end comes together on these rigs.
Much appreciated!
For anyone who might be interested, I’ve posted another episode of my FJ55 rescue project. I’m not doing this to get YouTube famous (I’m nowhere near charismatic enough to pull that off): I’m just wanting to document and share the things I learn as I bring this Pig back to life.
I’ve been working on my door swap on Yukon Jack. In a nutshell, I’m swapping out a set of rusty/damaged late front doors for a set of early vent window doors that are in much better shape and that happen to be the correct colour.
The first thing I learned during this swap is that the early door latch will not play nicely with the late striker. So I swapped the late latch assembly into the early door. The difference between the two is subtle but significant enough to prevent the early door from closing.
The latch assemblies appear to be otherwise identical, though I had to swap the handles as well, due to the differences in the actuator.
With those changes, the early door opens and closes nicely.
While I was working inside the door, I noticed that the lower window channel bracket had broken free from the door shell, making the window frame very floppy. I drilled a couple of holes in the door, clamped the bracket in place and then plug welded it from the outside. Solid as a rock now!
It seems as though a previous owner had tried to fix the floppy window frame by pop riveting a strip of steel on the front and back sides of the window frame. With the frame now properly welded in place, I was able to remove those reinforcements and weld up the holes left by the rivets.
Lastly, I gave the “new” door a bit of a polish. It’s amazing to see the old paint come back to life. I just love the blue colour on these old Pigs.
Is pic 2 a cartridge repair 30/06 case?
Haha, now that you mention it sure does! I’ll take a closer look at it later. As we all know, previous owners do the darnedest things!
